How do I define a "null" password in the connection profile? [message #1717653] |
Tue, 15 December 2015 14:51 |
I am trying to connect to a server using Kerberos but the connection profile insists on having a password. The account doesn't have a password (not an enabled one at least).
It would appear that the connector is adding a 0 length string to the properties and the server is refusing the connection as password authentication has been revoked.
How can I define a connection that uses a properties file that I define and load it?
Or how can I let the mask know that the "Password:" field should be ignored.
There is no need to save a password, or pop up the connect dialogue when Kerberos is being used either.
Re: How do I define a "null" password in the connection profile? [message #1717674 is a reply to message #1717663] |
Tue, 15 December 2015 17:04 |
For some strange reason adding the property "user=kerberos" caused it to work.
To recap:
I configured a DB2 driver using the option for a JDBC4 driver with "using Kerberos Security Default" in the name.
Added 2 properties:
kerberosServerPrinicipal=db2/db2server.private.lan@PRIVATE.LAN
user=kerberos
Configured eclipse command line to append the vm agruement -vmargs -Djava.security.auth.login.config=C:/../../JaasLogin.cfg
The connection identity, KeyTab,,local principal, etc. are configured in C:/.../JaasLogin.cfg under the entry .
FUDForum. Page generated in 0.03490 seconds
