Home » Modeling » QVT-OML » QVTo Trace Editor doesn't show properties of elements
QVTo Trace Editor doesn't show properties of elements [message #1717595] Tue, 15 December 2015 02:50 Go to next message
I'm using QVTo 3.5.0.v20150603-1058.
I can't see any properties of objects (see attached screenshot). How can I fix it?
Also I've attached the trace.
index.php/fa/24324/0/
Re: QVTo Trace Editor doesn't show properties of elements [message #1717605 is a reply to message #1717595] Tue, 15 December 2015 04:06 Go to previous messageGo to next message
HI
It's a standard EMF editor. Use "Show Properties View" to see the
Properties View.
Ed Willink
On 15/12/2015 07:50, Denis Nikiforov wrote:
> Hi
Re: QVTo Trace Editor doesn't show properties of elements [message #1717610 is a reply to message #1717605] Tue, 15 December 2015 04:47 Go to previous messageGo to next message
In Properties View I can see only properties of qvtotrace-file (path, size, last modified, ...).
I've got it! I saw element properties in debug mode:
https://wiki.eclipse.org/images/b/bd/Debug-trace-view.png
There is a real classes (Model, Package, ...) Instead of EObjects and real properties.
Is it impossible to see the same detailed information not only in debug mode but also in simple QVT Trace Editor?
Re: QVTo Trace Editor doesn't show properties of elements [message #1717638 is a reply to message #1717610] Tue, 15 December 2015 08:45 Go to previous message
Correction: You can Open with the Sample Reflective Ecore Editor to get
the really standard EMF editor, with a Properties View.
The Operation QVT Trace Editor is a customized view in which all the
properties are represented in the visible text.
However neither editor allows you to trace from the EObject reference to
the EObject, which is where you could find more information.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=484391 raised
Ed Willink
> real properties.
Previous Topic:Implicit conversion of string literals into instances of custom data types
Next Topic:[QVTo] Transform an object by a condition.
Current Time: Fri Jul 18 19:09:56 EDT 2025
Powered by FUDForum. Page generated in 0.04287 seconds
