Home » Eclipse Projects » Eclipse 4 » Null Worbench after changing bundle configurations( The infamous ColorAndFontProviderImpl.getCurrentTheme() NullPointer)
Null Worbench after changing bundle configurations [message #1716367] Thu, 03 December 2015 09:50 Go to next message
Piero Campalani is currently offline Piero CampalaniFriend
Dear list,
while overhauling all my bundles/features dependencies I managed to achieve validation of my product's plug-ins (Run Configuration -> Plug-ins -> Validate).
I have been happy and satisfied for a little while, as soon as I realized that my application now throws hundreds of NullPointers for it cannot get the instance of the org.eclipse.ui.internal.Workbench.
I have seen this issue around in a couple of places, but they only suggest to clear the workspace, clean Eclipse caches, even move the project to another folder, etc..
Here is the stack trace:
	at org.eclipse.ui.internal.themes.ColorAndFontProviderImpl.getCurrentTheme(ColorAndFontProviderImpl.java:51)
	at org.eclipse.ui.internal.themes.ColorAndFontProviderImpl.getColor(ColorAndFontProviderImpl.java:47)
	at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.findColorByDefinition(CSSSWTColorHelper.java:319)
	at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.getRGB(CSSSWTColorHelper.java:70)
	at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.getSWTColor(CSSSWTColorHelper.java:58)
	at org.eclipse.e4.ui.css.swt.properties.converters.CSSValueSWTColorConverterImpl.convert(CSSValueSWTColorConverterImpl.java:46)
	at org.eclipse.e4.ui.css.swt.properties.converters.CSSValueSWTColorConverterImpl.convert(CSSValueSWTColorConverterImpl.java:1)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.convert(AbstractCSSEngine.java:1077)
	at org.eclipse.e4.ui.css.swt.properties.custom.CSSPropertye4TabOutline.applyCSSProperty(CSSPropertye4TabOutline.java:31)
	at org.eclipse.e4.ui.css.swt.properties.AbstractCSSPropertySWTHandler.applyCSSProperty(AbstractCSSPropertySWTHandler.java:40)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyCSSProperty(AbstractCSSEngine.java:722)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyleDeclaration(AbstractCSSEngine.java:520)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyles(AbstractCSSEngine.java:413)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyles(AbstractCSSEngine.java:354)
	at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.applyStyles(ThemeEngine.java:512)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$11.setClassnameAndId(PartRenderingEngine.java:1321)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.setCSSInfo(SWTPartRenderer.java:111)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.bindWidget(SWTPartRenderer.java:128)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createWidget(StackRenderer.java:620)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:69)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4590)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:108)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:663)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1074)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:331)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
This happens independently whether I launch the product directly, or via a Run Configuration with additional required plug-ins included.
Thanks for trying to help,
-Piero !
Re: Null Worbench after changing bundle configurations [message #1716418 is a reply to message #1716367] Thu, 03 December 2015 15:38 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de AlwisFriend
Check your product or application setting in your Run Configuration. You're launching an E4 application, and not an E3.x Workbench application.
Eclipse Platform committer. Ask me about Eclipse support, training, and consulting.
Re: Null Worbench after changing bundle configurations [message #1716423 is a reply to message #1716418] Thu, 03 December 2015 16:04 Go to previous messageGo to next message
Hi Brian,
I am actually running the product as an E4 application (org.eclipse.e4.ui.workbench.swt.E4Application).
Why do you think I am running it as an E3 one?
thanks,
-Piero
Re: Null Worbench after changing bundle configurations [message #1716426 is a reply to message #1716423] Thu, 03 December 2015 16:39 Go to previous messageGo to next message
Piero Campalani wrote on Thu, 03 December 2015 11:04
If you're running an E4 app, don't include any bundles matching org.eclipse.ui.*.
Brian.
Re: Null Worbench after changing bundle configurations [message #1716431 is a reply to message #1716426] Thu, 03 December 2015 17:07 Go to previous messageGo to next message
Woah... thank you Brian, did not know about this, guess I should have read more about E4.
Do you mean I should not include the org.eclipse.ui plug-in neither?
Re: Null Worbench after changing bundle configurations [message #1716432 is a reply to message #1716431] Thu, 03 December 2015 17:18 Go to previous message
That's right!
Previous Topic:e4 Best Practice to avoid extension points
Next Topic:Eclipse e4 - Part menus
Current Time: Thu Oct 22 07:54:58 GMT 2020
Powered by FUDForum. Page generated in 0.02182 seconds
