Re: Query UML-model with UML-profile: no matches [message #1716222 is a reply to message #1716160] |
Wed, 02 December 2015 10:18 |
Jens Bürger Messages: 55 Registered: October 2012 |
Member |
Hi Zoltan,
thank you for your quick reply.
Zoltan Ujhelyi wrote on Tue, 01 December 2015 14:31
The only thing that comes to my mind that could cause such issues that the stereotypes in your instance model were using the dynamic version of the profile (e.g. not the one you have generated from the genmodel), while the query specification uses the static version.
This seems to be the case.
Looking at the XML file, appartently only the *profile.uml-file is referenced. However, I'm not sure how to tell Papyrus to apply the Ecore-version.
A further idea to check to turn on the dynamic mode in IncQuery.
I did that, it doesn't seem to make any difference.
For further investigation, I provide a zip-file containing
- the plugin containing the UML profile
- the EIQ-plugin also containing 2 minimalistic test models
Attachment: eiqtest.zip
(Size: 80.67KB, Downloaded 137 times)
FUDForum. Page generated in 0.03758 seconds
