[EMF Forms] Error running org.eclipse.emf.ecp.makeithappen.application.sample.e3 [message #1716144] |
Tue, 01 December 2015 16:48 |
Jim Boone Messages: 15 Registered: August 2015 Location: North Carolina |
Hi!
I am trying to wrap my brain around EMF Forms and hope to use them in my current project. Unfortunately, I can't seem to get started running the subject sample app. After creating the "Make it happen: sample e3 application" and trying to run it, I get the exception shown below. I know it can't find the EMFFormsRendererService, but why? I was hoping to learn from this sample but I can't even get it working Does anyone have any ideas? I am using version 1.7.0 of the plugins. Thanks in advance.
!ENTRY org.eclipse.equinox.ds 1 0 2015-12-01 11:35:28.278
!MESSAGE Could not bind a reference of component org.eclipse.emfforms.swt.core.rendererfactory. The reference is: Reference[name = EMFFormsAdditionalRendererService, interface = org.eclipse.emfforms.spi.swt.core.EMFFormsAdditionalRendererService, policy = dynamic, cardinality = 0..n, target = null, bind = addEMFFormsAdditionalRendererService, unbind = removeEMFFormsAdditionalRendererService]
org.eclipse.emf.ecp.ui.view.ECPRendererException: No EMFFormsRendererService available!
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:95)
at org.eclipse.emf.ecp.makeithappen.application.sample.e3.View.createPartControl(View.java:68)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:151)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:143)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:341)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:525)
Re: [EMF Forms] Error running org.eclipse.emf.ecp.makeithappen.application.sample.e3 [message #1716204 is a reply to message #1716144] |
Wed, 02 December 2015 08:38 |
Eugen Neufeld Messages: 174 Registered: May 2015 |
Hi Jim,
how did you start the example? Did you use the product that is part of the example application?
Your log shows two things:
This is a log of ds because an optional service is not there. There is a long running bug opened against the platform about this log.In short: You can ignore this.
The actual Error is this:
If you didn't use the product to start the demo, you probably are missing this bundle: org.eclipse.emf.ecp.view.core.swt and its dependencies.
To run the demo you also will need:
- org.eclipse.emf.ecp.view.group.ui.swt
- org.eclipse.emf.ecp.view.horizontal.ui.swt
- org.eclipse.emf.ecp.view.vertical.ui.swt
Eugen
Eugen Neufeld
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.02513 seconds
