Home » Newcomers » Newcomers » JAVA_HOME setting(Using an ant external tool, JAVA_HOME is wrong.)
JAVA_HOME setting [message #1716143] Tue, 01 December 2015 16:45
Christopher V. Kimball is currently offline Christopher V. KimballFriend
Use ant to build two projects A, B. Both projects have their Enable project specific settings UNchecked. The overall Java compiler for Eclipse is Java SE 8 (OSX Default).
In project A I can run the building ant script using the external tools configurations with the JRE taken from the workspace.
In project B I can run the building ant script using the external tools configurations with the JRE taken from the "separate JRE" specified as SE 8 (OSX Default). When I take it as the JRE taken from the workspace, the ant script fails with a bad JAVA_HOME value. The JAVA_HOME value shown includes the path from the JDK to the JRE itself, which is certainly an error.
But I haven't tried to make these two projects different. How can the workspace JRE be different between them?
Where would I set a project's JAVA_HOME path?
Chris KImball
Previous Topic:Eclipse language behaving wierdly
Next Topic:Mars question - window creation
Current Time: Tue Feb 18 10:14:52 GMT 2020
Powered by FUDForum. Page generated in 0.03786 seconds
