Re: sh -c make dep make: *** No rule to make target `IP_EncDec.d', needed by `dep'. Stop [message #1722594 is a reply to message #1722525] |
Sat, 06 February 2016 10:20 |
Hi Sharon
I suppose this is the path of your Titan plugin for Eclipse. There is another part of Titan: the Titan Ecxecutor. It contains all executables, such as compiler, mctr_cli (main controller , command line version) and supporting utilities. Titan plugin uses its resources to compile and execute ttcn files/projects. $TTCN3_DIR shall be set to the root of Titan Executor. In Eclipse you should set this folder as Titan install path (Window>Preferences>Titan Preferences). The root directory of Titan Executor contains these subdirectories: bin, demo, doc, etc, help, include, lib, man. I suggest to read at first the usrguide.pdf and the installguide.pdf. It can be found in the doc folder.
BR Jeno Balasko, Titan Team, Ericsson
Re: sh -c make dep make: *** No rule to make target `IP_EncDec.d', needed by `dep'. Stop [message #1722595 is a reply to message #1722594] |
Sat, 06 February 2016 10:35 |
hmm, the folder name seems to be the name of the Titan Executor, Linux, Sled but it is under "plugins".
It was a little bit confusing.
If everything is set properly, and you type from command line
> compiler -v
then the version of your compiler appear. But I think the location of you Titan executor is really wrong:
/home/sharon/Documents/ttc3/eclipse/plugins/ttcn3-5.4.pl0-linux32-gcc4.3-sled11.1
is force Eclipse to analyze dir ttcn3-5.4.pl0-linux32-gcc4.3-sled11.1 as a plugin. Eclipse cannot do it but spend time.\
I would suggest to move the last folder under ttcn3:
/home/sharon/Documents/ttc3/ttcn3-5.4.pl0-linux32-gcc4.3-sled11.1
After this you should set $TTCN3_DIR, $LD_LIBRARY_PATH and $PATH according to the installguide.pdf and set the "Titan install path" in Eclipse to this directory.
BR
Jeno
FUDForum. Page generated in 0.05490 seconds
