Re: Impossible to valid a text on get-editbox -after [get-label Name] | set-text [message #1715820 is a reply to message #1715802] |
Thu, 26 November 2015 12:46 |
you can find widget details following:
Widget information
Class: org.eclipse.swt.widgets.Text
extends org.eclipse.swt.widgets.Scrollable, org.eclipse.swt.widgets.Control, org.eclipse.swt.widgets.Widget
implements org.eclipse.swt.graphics.Drawable
WidgetID: Shell/Composite|5/Composite|0/Composite|1/Composite|0/PageBook|0/TabbedPropertyComposite|1/LayoutComposite|0/ScrolledComposite|1/LayoutComposite|0/LayoutComposite|0/LayoutComposite|0/LayoutComposite|0/CTabFolder|0/LayoutComposite|0/Section|0/LayoutComposite|2/Text|1
Style flags: 33572868 (Border)
Enabled: true
Focused: false
Visible: true
Reparentable: true
Text value:
Registered event listeners:
listener class: com.all4tec.ui.forms.widget.ExtendedTextWidget$1
extends org.eclipse.swt.events.KeyAdapter
implements org.eclipse.swt.events.KeyListener
events:
SWT.KeyUp
SWT.KeyDown
listener class: org.eclipse.ui.forms.widgets.FormToolkit$VisibilityHandler
extends org.eclipse.swt.events.FocusAdapter
implements org.eclipse.swt.events.FocusListener
events:
SWT.FocusIn
SWT.FocusOut
listener class: com.all4tec.ui.forms.widget.ExtendedTextWidget$2
events:
SWT.FocusIn
SWT.FocusOut
Re: Impossible to valid a text on get-editbox -after [get-label Name] | set-text [message #1732602 is a reply to message #1732096] |
Wed, 18 May 2016 06:04 |
hi,
I just try with this 2 script but no solution.
If I do this code on mode debug, I haven't problem.
with [get-view "Editor Properties" | get-section Details | get-editbox -after [get-label Name]] {
wait 3000
type-text titi
set-focus
key-type Enter
wait 3000
set-value "t"
wait 3000
set-focus
wait 3000
key-type Enter
Have you a other idea?
thanks,
jeremie
FUDForum. Page generated in 0.04467 seconds
