Home » Eclipse Projects » Vorto » Is there a code generator available for KURA??
Is there a code generator available for KURA?? [message #1715711] Wed, 25 November 2015 11:47 Go to next message
Chikkanahalli Venkataraju Sameer Nagegowda is currently offline Chikkanahalli Venkataraju Sameer NagegowdaFriend
No Message Body
Re: Is there a code generator available for KURA?? [message #1715888 is a reply to message #1715711] Fri, 27 November 2015 10:39 Go to previous messageGo to next message
Olaf Weinmann is currently offline Olaf WeinmannFriend
We have created a basic version of a Kura code generator and we are currently in discussion with the colleagues from Kura if we host it in the Vorto GitHub repo or if we contribute it to the Kura project. After we have answered this question the sources will be publicly available.
I'll keep you up-to-date!
Olaf
Re: Is there a code generator available for KURA?? [message #1730588 is a reply to message #1715888] Tue, 26 April 2016 22:48 Go to previous messageGo to next message
Marcus Munzert is currently offline Marcus MunzertFriend
we at Generative Software already have a code generator to generate a Kura application. Our generator is not developed by using the Vorto API for generator development but by using the so-called Virtual Developer API of our Virtual Developer Platform (for more details please see https://www.virtual-developer.com). Our code generator directly accesses the Vorto repository through its REST API. We are thinking about providing the generator as an open source project.
Also, we are currently developing a tighter integration of our Virtual Developer Platform with Vorto. With this it will become easy to develop, deploy and host code generators that consume Vorto information models.
We will write more about all that once our Kura code generator is publicly available and you can try it out yourself.
Marcus
CEO and President
Generative Software GmbH
Cornelia-Schlosser-Allee 15
79111 Freiburg
Germany
www.generative-software.de
Phone: +49 761 1562051
Fax: +49 761 7043098
The efficient use of software development
Re: Is there a code generator available for KURA?? [message #1807755 is a reply to message #1730588] Fri, 07 June 2019 13:16 Go to previous message
Andrew Smith is currently offline Andrew SmithFriend
"...once our Kura code generator is publicly available..."
Has the Kura code generator been made available yet?
Previous Topic:Multi-tenancy Concept Discussions
Next Topic:save bosch iot hub data
Current Time: Fri Jan 22 06:16:55 GMT 2021
Powered by FUDForum. Page generated in 0.01816 seconds
