getConfigLabelsByPosition [message #1715399] |
Mon, 23 November 2015 10:15 |
Bhagwan Moondra Messages: 9 Registered: May 2015 |
I have a NatTable implementation where-in I am applying custom label for specific columns and cells. If custom label is for complete column, then I use ColumnOverrideLabelAccumulator. If it is for certain cells of data layer, I override getConfigLabelsByPosition()
Basically, in my table I have header rows and data rows. For data rows, I need to have different styling for specific columns, hence I have defined labels for same and config registry for such labels.
Problem is, getConfigLabelsByPosition() is not getting called for all the columns. After getting LabelStack for certain column number "n", it throws an exception:
java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.nebula.widgets.nattable.data.ReflectiveColumnPropertyAccessor.getDataValue(ReflectiveColumnPropertyAccessor.java:58)
at org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsDataProvider.getDataValue(GlazedListsDataProvider.java:92)
at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getDataValue(DataLayer.java:132)
at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getDataValueByPosition(DataLayer.java:381)
What could be the reason that getConfigLabelsByPosition() is not getting called for specific column index. That too it gets called for header row, but never gets called for data row. I believe this overridden method shoul dbe called every time user changes position, and it should be called for all the column & row positions
FUDForum. Page generated in 0.03047 seconds
