Home » Modeling » GMF (Graphical Modeling Framework) » Problem with interpretation of XML representation of diagram layout(how to use the attributes (bendpoints/points, targetAnchor/id, targetAnchor/id) to redraw the connections)
Problem with interpretation of XML representation of diagram layout [message #1714759] Mon, 16 November 2015 12:53 Go to next message
nana eb is currently offline nana ebFriend
hey everbody,
after i draw a diagram with my own generated GMF-Editor (see Attachement1), i need to redraw it in another GUI. For that i'm using the XML file of the diagram, and i don't know how to use the XML information to redraw a connection in a right way.
Does anyone know how i can use the three values under the nodes "Edges":
1. bendpoints/points
2. sourceAnchor/id
3. targetAnchor/id
to draw a connection (or get the real bendpoints of a connection).
when i only use the attribute bendpoints/points, i get this (see Attatchment2) and as we see, most of the connections are not on the right place.
and i realized that the attributes sourceAnchor/id and targetAnchor/id are missing at some "edges" nodes (see attached XML file).
please, i really need help, any comment could be helpful.
thanks in advance ..
Nana
index.php/fa/23961/0/
index.php/fa/23962/0/
  • Attachment: Attachment1.png
    (Size: 15.31KB, Downloaded 388 times)
  • Attachment: Attachment2.png
    (Size: 16.20KB, Downloaded 395 times)
  • Attachment: XML.xml
    (Size: 13.18KB, Downloaded 131 times)
Re: Problem with interpretation of XML representation of diagram layout [message #1715019 is a reply to message #1714759] Wed, 18 November 2015 14:19 Go to previous messageGo to next message
anyone there who could help please :'(
Re: Problem with interpretation of XML representation of diagram layout [message #1718728 is a reply to message #1715019] Tue, 29 December 2015 13:51 Go to previous messageGo to next message
Fran Jimenez is currently offline Fran JimenezFriend
Hi, did you solve the problem?
I'm in the same situation. I'd like to get coordinates from bendpoints in a (x,y) way. How do you translate from bendpoints to coordinates?
Re: Problem with interpretation of XML representation of diagram layout [message #1719003 is a reply to message #1718728] Mon, 04 January 2016 11:59 Go to previous message
Hey, i did not solve the problem.
this problem is related to GMF, the values in the xml file are not correct.
Wlc
Previous Topic:GMF integrating with MultiPageEditorPart?
Next Topic:Did anyone met crash issue with SVG? How to solve?
Current Time: Sun Nov 29 15:08:41 GMT 2020
Powered by FUDForum. Page generated in 0.02035 seconds
