Home » Modeling » Papyrus » How to Adress Single Elements with an Css File(CSS)
How to Adress Single Elements with an Css File [message #1714512] Fri, 13 November 2015 10:31 Go to next message
Moritz Kiehl is currently offline Moritz KiehlFriend
Hi there
i am quiet new here
I´m working on a Project and want to Style different nodes/edges of the same type in different ways with an CSS file. Is there an posibillity to do this ? I already know how to do this with the Appearance Tab or how to Style all Nodes/edges of the same type with a css file.
Best regards
Moritz
Re: How to Adress Single Elements with an Css File [message #1714566 is a reply to message #1714512] Fri, 13 November 2015 15:32 Go to previous messageGo to next message
Mickael ADAM is currently offline Mickael ADAMFriend
Member
hi,
I don't understand what exactly you want to do but you can find many information on the official wiki.
HTH,
Mickaël
Re: How to Adress Single Elements with an Css File [message #1714572 is a reply to message #1714566] Fri, 13 November 2015 16:02 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
You can match single elements by name (or qualified name):
Class[qualifiedName="MyPackage::MyClass"]{
     fillColor: blue;
Or using named styles (CSS Classes), which need to be applied manually from the "Style" tab of the properties view ('Applied Styles'):
.myClass1 {
    fillColor: blue;
.myClass2 {
    fillColor: red;
Edit: In theory, you could also use CSS Ids (#myClass1), which are unique (Unlike CSS Classes), but since this seemed seldom useful, it isn't exposed in the properties view anymore. However, the property exists and is supported, so you could customize the properties view to expose it again.
HTH,
Camille
Camille Letavernier
[Updated on: Fri, 13 November 2015 16:05]
Report message to a moderator
Re: How to Adress Single Elements with an Css File [message #1715214 is a reply to message #1714572] Fri, 20 November 2015 09:57 Go to previous message
Thank you. Both options are doing well in my Project.
Moritz Kiehl
Previous Topic:Association behaviour in reaction to graphical Drag and Drop
Next Topic:Deadlock using TransactionalEditingDomain in Papyrus\CDO
Current Time: Thu Mar 04 16:19:51 GMT 2021
Powered by FUDForum. Page generated in 0.01969 seconds
