Re: Sources - Which Tag for current development in 1.2.1 [message #1714477 is a reply to message #1714472] |
Thu, 12 November 2015 23:08   |
Hi Ralph,
Sorry, I neglected to create a tag for the Mars release. Usually I create a "Final" tag for each service release version which matches up with each eclipse service release (e.g. 1.2.1 should have a 1.2.1.Final tag for Mars 4.5.1) but this time I forgot - mea culpa I shall report for my flogging in the morning...
I'm afraid for now you will have to navigate to the commit record that corresponds to this build, which is 4795a77d7ffc758bbc70a0685f7558cc003e701e. From the eclipse History viewer, you should be able to check out that specific commit using eGit.
FWIW, I was planing on doing a "Final" tag for both Mars and Luna in the next couple of days. I hope this isn't causing you too much pain.
Bob
Re: Sources - Which Tag for current development in 1.2.1 [message #1715458 is a reply to message #1715353] |
Mon, 23 November 2015 18:50   |
You are correct - this 1.2.1.Final tag is not where it should be! I found a problem which I think explains the issues you're seeing (maybe ?!) Two of the example plugins (customtask and dynamic) make reference to a non-existent runtime ID, but this isn't caught during the extension plugin loading by the TargetRuntime class and causes all kinds of problems.
I'm trying to figure out how to either move or delete this tag, but eclipse git isn't letting me do this (it claims I don't have "Push rights" to delete a tag).
Anyway, as soon as this is straightened out I'll let you know. Meantime I was able to clone your imixs repo and I'm testing with it now. Looks like there are some other problems going on. Will keep you posted.
FUDForum. Page generated in 0.08014 seconds
