Home » Eclipse Projects » Gemini » JUnit Plugin Test using Gemini Blueprint(JUnit Plugin Test using Gemini Blueprint)
JUnit Plugin Test using Gemini Blueprint [message #1714347] Wed, 11 November 2015 22:51 Go to next message
Hi all,
I'm running test against simple application that depends on Gemini blueprint. The test is run from Eclipse's JUnit Plugin Test. The app consists of 1 bundle and 1 test fragment.
Below is the content of spring context file in META-INF/spring:
<beans xmlns="http://www.springframework.org/schema/beans"
	   xmlns:osgi="http://www.eclipse.org/gemini/blueprint/schema/blueprint"
	   xsi:schemaLocation="http://www.springframework.org/schema/beans
http://www.springframework.org/schema/beans/spring-beans.xsd
http://www.eclipse.org/gemini/blueprint/schema/blueprint/gemini-blueprint.xsd">
    <bean class="com.mycompany.service.impl.SpringContextProvider"/>
</beans>
Below is the content of SpringContextProvider class:
public class SpringContextProvider implements ApplicationContextAware
	private static ApplicationContext context;
	public void setApplicationContext(ApplicationContext injectedContext) throws BeansException
		context = injectedContext;
	static final ApplicationContext getContext(){return context;}
The above snippets runs well in Eclipse's OSGI Framework runner where the Spring's ApplicationContext is injected properly.
but in JUnit Plugin Test, the following test fails:
@Test
public void testSpringContextProviderAvailability()
	assertNotNull(SpringContextProvider.getContext());
Below is what the log says:
SEVERE: Expecting state (RESOLVING_DEPENDENCIES) not (INTERRUPTED) for context [OsgiBundleXmlApplicationContext(bundle=com.mycompany.service, config=osgibundle:/META-INF/spring/*.xml)]; assuming an interruption and bailing out
I was wondering if it is possible to run test against bundles containing Gemini Blueprint dependency or else I have to use test fixtures provided by GB instead.
Any help would be greatly appreciated.
Thanks & Regards,
Setya
Re: JUnit Plugin Test using Gemini Blueprint [message #1714517 is a reply to message #1714347] Fri, 13 November 2015 06:01 Go to previous message
Hi All,
Any updates ?
Thanks & Regards,
Setya
Previous Topic:Test using AbstractConfigurableBundleCreatorTests
Next Topic:[Gemini Blueprint] Testing Eclipse Plugin Projects
Current Time: Fri May 16 17:54:56 EDT 2025
Powered by FUDForum. Page generated in 0.06058 seconds
