Home » Eclipse Projects » Sirius » Defining queries in AQL?
Defining queries in AQL? [message #1714049] Mon, 09 November 2015 14:51 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I did some steps in migrating the acceleo services in an editor to AQL.
In general that process went rather smooth. However I encountered one situation where I saw an advantage of the Acceleo services over (the current implementation of) AQL.
In order to represent attributes of a class like concept, I created an Acceleo query providing the textual representing. However, that representation could become rather complex which resulted into decomposing the query into multiple ones.
Example:
[query public getRepresentation(c : MultiplicityConstant) : String =
c.name + ' = ' + c.value.getExprRepr()
[query public getExprRepr(e: Expression) : String =
if (e=null) or (e.oclIsUndefined())
then
    'undefined'
else
    if e.oclIsTypeOf(IntegerLiteral)
    endif
endif
Then I invoke getRepresentation() from my VSP.
If I would like to do things like this using AQL, I need the ability to define AQL modules that contain queries like described above.
Are there any plans to support something like this?
Greetings,
Wilbert.
Re: Defining queries in AQL? [message #1714142 is a reply to message #1714049] Tue, 10 November 2015 08:45 Go to previous messageGo to next message
Florian Barbin is currently offline Florian BarbinFriend
Hi Wilbert,
The purpose of AQL is to provide a "lightweight" Query Language for
interpreted expressions. AQL is a sub-part of Acceleo project and is not
intended to replace it as a Model To Text implementation.
For really complex queries, I recommend you to delegate the job to an
external java service.
Florian - Obeo
Re: Defining queries in AQL? [message #1714186 is a reply to message #1714142] Tue, 10 November 2015 14:57 Go to previous message
Hi Florian,
Thanks for your answer. I understand the positioning of AQL a little bit better now. Still I appreciate the ability to express certain queries in OCL over the ability to code them into java. Luckily that remains possible (for the time being).
Greetings,
Wilbert.
Previous Topic:How to forbid two views with same name in the same project ?
Next Topic:Programmatically Opening Diagram Errors
Current Time: Tue Mar 02 15:23:05 GMT 2021
Powered by FUDForum. Page generated in 0.01642 seconds
