Re: How to merge two *.uml models in Papyrus? [message #1713970 is a reply to message #1713931] |
Mon, 09 November 2015 08:48 |
If you are using Papyrus, why don't you just import the model bu using
Papyrus menu?
(right-click the root of your model in the Model Explorer, select
Import->Import Package From User Model. Finally select the model you
want to import).
Best,
Víctor
El 08/11/2015 a las 18:34, Ed Willink escribió:
> Hi
> If you open one *.uml with the UML Model Editor, you can
> either Load Resource for the other *.uml and DND within the one tree
> editor,
> or open the other *.uml with the UML Model Editor and DND between tree
> editors.
> Regards
> Ed Willink
> On 08/11/2015 12:43, Ri Fr wrote:
>> I would like to combine 2 uml files into one; or at least import all
>> Packages from one model into the other. Trying all manners of import
>> the nest I could do was open both models on a single project and drag
>> packages from one model into the other; all classifier names were
>> italicized to show they were not native to the target packages. How
>> can I have a true merge of 2 models into one (without manually
>> drag/drop and all classifiers shown as native)? Thanks for any
>> suggestion!
Re: How to merge two *.uml models in Papyrus? [message #1714045 is a reply to message #1714042] |
Mon, 09 November 2015 14:27 |
The greyed-out italic labels indicate read-only elements: they are not
editable in this editor without explicit action to make them writable,
to prevent accidental modification of resources referenced by but not
"owned by" the model that the user intends to be editing.
The Import User Package dialog does also have an option to copy the
selected package(s) into the "importing" model, but I have never used
it.
HTH,
Christian
On 2015-11-09 14:09:28 +0000, Ri Fr said:
> Thank you very much, Import User package from Root Menu context menu
> works! But the importer Classifiers are still in italic in Model
> explorer... does it mean anything? otherwise I'm OK with your
> suggestion, thansk
FUDForum. Page generated in 0.03854 seconds
