Home » Newcomers » Newcomers » eGit question. One project showing as seperate folder in eclipse...
eGit question. One project showing as seperate folder in eclipse... [message #1713820] Fri, 06 November 2015 17:22 Go to next message
Jeremy Wilcock is currently offline Jeremy WilcockFriend
I'm fairly new to eclipse, and eGit. I've imported a repo (that does not contain any eclipse files, source only) as a Java Project. It imports fine other than I have one package that is not showing like the others. See attached image.
All other packages are showing as indented inside the src folder, but there a single folder that is shown outside the src folder with "src/" prefixed to it. I'm not sure why this is as the folder structure on my hard drive isn't any different for that package. Any idea why this would happen?
index.php/fa/23855/0/
Re: eGit question. One project showing as seperate folder in eclipse... [message #1713834 is a reply to message #1713820] Fri, 06 November 2015 19:41 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
You mean to say that, in your project's filesystem, assign7 is a sibling
to assign1, 2, 3, etc.?
Re: eGit question. One project showing as seperate folder in eclipse... [message #1713844 is a reply to message #1713834] Fri, 06 November 2015 23:30 Go to previous messageGo to next message
Yes. That is correct, here's a screen shot of the file system:
index.php/fa/23857/0/
Re: eGit question. One project showing as seperate folder in eclipse... [message #1714031 is a reply to message #1713844] Mon, 09 November 2015 13:42 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
What are the contents of the .classpath file in the project?
Previous Topic:Eclipse has an installer!
Next Topic:Sonar-Plugin / Error: Could not find or load main class MAVEN_OPTS
Current Time: Wed Jan 22 06:22:00 GMT 2020
Powered by FUDForum. Page generated in 0.03530 seconds
