Home » Eclipse Projects » RCP Testing Tool » [SOLVED] base_dir in Linux(#base_dir #Linux)
icon5.gif  [SOLVED] base_dir in Linux [message #1713761] Fri, 06 November 2015 08:34 Go to next message
Dear all Smile ,
I have 2 quick questions.
I have set up the continuous integration process in Windows.
1.Is RCP TT continuous integration process full compatible with Linux (I mean RCPTT runner also) ?
2. Do you know what is the base dir for rcptt ?
I mean if I don't specify the path but only the filename where the application looking for the file ?
Thank you guys.
[Updated on: Mon, 16 November 2015 12:09] by Moderator
Re: 2 quick questions related #base_dir & #Linux [message #1714247 is a reply to message #1713761] Tue, 10 November 2015 22:44 Go to previous messageGo to next message
Hi Angelo,
Regarding your questions:
1) Yes, both RCPTT IDE and Runner are compatible with Linux.
2) I'm not quite sure I got you right. Where do you put this base dir?
Kind regards,
Ulyana.
Re: 2 quick questions related #base_dir & #Linux [message #1714269 is a reply to message #1714247] Wed, 11 November 2015 04:16 Go to previous messageGo to next message
Hello Ulyana! Welcome back.
Awesome ! Good to know is full compatible with Linux.
Regarding the base dir I mean
If I insert in the path only the file name for example
$path = pippo.txt
delete-file $path
The point is where RCP TT looking for the file by default if it is no specify the path ?
Thank you in advance.
Re: 2 quick questions related #base_dir & #Linux [message #1714729 is a reply to message #1714269] Mon, 16 November 2015 04:40 Go to previous messageGo to next message
Hi Angelo,
Looks like it's in a RCPTT installation directory.
You can check this out by executing
uri-from-path -path "file.txt" | log
E.g. on my MacOS I have it in
file:/Users/Ulik_MacAir/Downloads/!%20RCPTT/rcptt-2.0.2/rcptt.app/Contents/MacOS/file.txt
Kind regards,
Ulyana.
Re: 2 quick questions related #base_dir & #Linux [message #1714739 is a reply to message #1714729] Mon, 16 November 2015 05:43 Go to previous message
Good to know Ulyana,
Thank you.
Previous Topic:RCPTT and nebula grid
Next Topic:Right mouse click
Current Time: Sat Jul 19 07:57:55 EDT 2025
Powered by FUDForum. Page generated in 0.26019 seconds
