Home » Newcomers » Newcomers » Can't install eclipse
Can't install eclipse [message #1713652] Thu, 05 November 2015 18:12 Go to next message
Pablo Salas is currently offline Pablo SalasFriend
Hello, I downloaded the files eclipse -inst-win64 and jdk-7u79-windows-i586.
Installed java first and then tried to install eclipse, but it opens the browser giving me the messaje "java for windows missing", as you can see in the picture.
I tried installing different versions of java , uninstalling them, etc. but eclipse is not installing, it keeps showing that error. Sad
Help me please, thank you in advance.
Re: Can't install eclipse [message #1713659 is a reply to message #1713652] Thu, 05 November 2015 19:22 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> I tried installing different versions of java , uninstalling them, etc. but eclipse is not installing, it keeps showing that error. :(
Read sticky posts at forum's top, in particular the one about Eclipse
won't start.
https://www.eclipse.org/forums/index.php/f/89/
Re: Can't install eclipse [message #1713683 is a reply to message #1713652] Thu, 05 November 2015 22:37 Go to previous messageGo to next message
Solved by installing the 32 bits version, my sistem is 64 bits though.
Re: Can't install eclipse [message #1713809 is a reply to message #1713683] Fri, 06 November 2015 16:53 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Just because your OS is 64-bit does not mean that the version of Java you installed is 64-bit. 32-bit applications (including Java and Eclipse) can run just fine on 64-bit systems.
The real requirement, as described in the announcement message that Russell referred to, is that the bit-ness of Eclipse and Java match, regardless of your system OS bit-ness.
Re: Can't install eclipse [message #1819004 is a reply to message #1713809] Sat, 04 January 2020 14:15 Go to previous messageGo to next message
Ian Grainger is currently offline Ian GraingerFriend
I read the post. No useful info (it refers to problems running, not installing).
I have a 64 bit Windows 10 Dell laptop. I've installed the JDK for 64 bit windows, but trying to run the eclipse installer keeps sending me to a page telling me to install 64 bit java. I follow the link and install 64 bit java, and then it just shows me the message again.
So far hating the world of Java development! ;)
Re: Can't install eclipse [message #1819017 is a reply to message #1819004] Sat, 04 January 2020 20:05 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Whose 64-bit Java? Different builds may or may not set the information that the installer is searching for.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Can't install eclipse [message #1819021 is a reply to message #1819017] Sun, 05 January 2020 07:37 Go to previous messageGo to next message
Where is your Java installation physically located on your machine? I.e., what's the absolute path for the java.exe of that Java installation? What does "echo %JAVA_HOME" print when executed on a cmd.exe command line? What does "java -version" print when executed on a cmd.exe command line?
It's possible that the installer doesn't find the Java version you have properly installed. Thought that seems unlikely, I'd really like to get to the bottom of such a problem and can only do that if you provide some more details.
Ed Merks
Re: Can't install eclipse [message #1824210 is a reply to message #1819021] Thu, 09 April 2020 15:30 Go to previous messageGo to next message
Did you try the installer?
Ed Merks
Re: Can't install eclipse [message #1824237 is a reply to message #1824210] Fri, 10 April 2020 13:57 Go to previous message
So you downloaded and ran this?
https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2020-03/R/eclipse-inst-win64.exe
And that and and finished successfully?
Ed Merks
Previous Topic:Help needed importing Jersey libraries
Next Topic:Error making JAXB Classes
Current Time: Wed Aug 04 01:11:02 GMT 2021
Powered by FUDForum. Page generated in 0.02964 seconds
