Home » Eclipse Projects » RCP Testing Tool » can the skipexecution tag be used with the runner when executing a suite?(I QA development projects and have frequent development refactoring and need to skip tests in some areas while its being worked on)
can the skipexecution tag be used with the runner when executing a suite? [message #1713630] Thu, 05 November 2015 09:55 Go to next message
No Message Body
Re: can the skipexecution tag be used with the runner when executing a suite? [message #1713636 is a reply to message #1713630] Thu, 05 November 2015 10:28 Go to previous messageGo to next message
Miss Message Body
Re: can the skipexecution tag be used with the runner when executing a suite? [message #1713726 is a reply to message #1713636] Fri, 06 November 2015 03:42 Go to previous messageGo to next message
I answer you here https://www.eclipse.org/forums/index.php/t/1071856/
Re: can the skipexecution tag be used with the runner when executing a suite? [message #1713783 is a reply to message #1713726] Fri, 06 November 2015 11:01 Go to previous messageGo to next message
I saw that, however I am executing the runner in batch, no POM. I have added the tag to the tests I need skipped, without effect...
Re: can the skipexecution tag be used with the runner when executing a suite? [message #1714735 is a reply to message #1713783] Mon, 16 November 2015 05:05 Go to previous messageGo to next message
Hi Walter,
For a runner execution, please use -skipTags argument:
-skipTags Semicolon-separated list of tags. Test cases containing any of listed tags are not be executed. The default value is 'skipExecution'.
Kind regards,
Ulyana.
Re: can the skipexecution tag be used with the runner when executing a suite? [message #1714925 is a reply to message #1714735] Tue, 17 November 2015 12:05 Go to previous message
thank you
Previous Topic:Right mouse click
Next Topic:Guidelines for delimiters in paths
Current Time: Mon Jul 14 15:48:13 EDT 2025
Powered by FUDForum. Page generated in 0.07451 seconds
