Home » Eclipse Projects » WindowBuilder » Fresh Eclipse Install and Window Builder Design tab crash(New install simple test and crashes)
Fresh Eclipse Install and Window Builder Design tab crash [message #1713176] Sun, 01 November 2015 21:08 Go to next message
I have a fresh install of Eclipse IDE for Java Developers that includes WindowBuilder and a few other packages.
I am trying to learn how to use WB and when I open a file with WindowBuilder Editor, the source tab looks fine, but if I click the DESIGN tab a progress window opens and then waits a short time and eclipse crashes.
I have tried simple files freshly created by eclipse as well as existing code.
The last time I got these messages, but they are not constant, so may just be noise
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
java: ../../src/xcb_io.c:179: dequeue_pending_request: Assertion `!xcb_xlib_unknown_req_in_deq' failed.
The simple source file is
package myname;
import java.awt.BorderLayout;
import java.awt.EventQueue;
import javax.swing.JFrame;
import javax.swing.JPanel;
import javax.swing.border.EmptyBorder;
public class MainFrame extends JFrame {
	private static final long serialVersionUID = 1L;
	private JPanel contentPane;
	 * Launch the application.
		EventQueue.invokeLater(new Runnable() {
			public void run() {
				try {
					MainFrame frame = new MainFrame();
					frame.setVisible(true);
				} catch (Exception e) {
					e.printStackTrace();
	 * Create the frame.
	public MainFrame() {
		setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		setBounds(100, 100, 450, 300);
		contentPane = new JPanel();
		contentPane.setBorder(new EmptyBorder(5, 5, 5, 5));
		contentPane.setLayout(new BorderLayout(0, 0));
		setContentPane(contentPane);
I also added a couple of screenshots as well
Any suggestions to get more specific details on why this is crashing?
This is really weird since this is a standard install!
Tom
Re: Fresh Eclipse Install and Window Builder Design tab crash [message #1713540 is a reply to message #1713176] Wed, 04 November 2015 16:32 Go to previous messageGo to next message
I'm having the exact same issue, WindowBuilder was working fine until I updated from Ubuntu 15.04 to 15.10, and I suspect it has something to do with 32 bit vs 64 bit java. Have you looked into that at all?
Re: Fresh Eclipse Install and Window Builder Design tab crash [message #1713548 is a reply to message #1713540] Wed, 04 November 2015 22:56 Go to previous messageGo to next message
I installed the Oracle Java and it worked fine.
Windows Builder does not seem to like OpenJDK
tom
Re: Fresh Eclipse Install and Window Builder Design tab crash [message #1713690 is a reply to message #1713548] Thu, 05 November 2015 20:40 Go to previous messageGo to next message
Sounds like that version of OpenJDK is buggy. Use Oracle Java or wait for the inevitable OpenJDK fix. I don't see anything here that indicates a bug in WindowBuilder itself.
Re: Fresh Eclipse Install and Window Builder Design tab crash [message #1771727 is a reply to message #1713690] Tue, 29 August 2017 19:35 Go to previous message
i have installed neon with oracle-java8 in ubuntu-gnome 17.04 and crash it with windowbuilder
Previous Topic:WindowBuilder Pro Zip Installation
Next Topic:Need help about palette Contribution for custom Element
Current Time: Fri Nov 07 02:26:16 EST 2025
Powered by FUDForum. Page generated in 0.04881 seconds
