Re: How to add icons to Table rows [message #1712551 is a reply to message #1712310] |
Mon, 26 October 2015 10:46 |
Le 22/10/2015 22:52, Yariv Amar a écrit :
> in the basic family example, i notice that when you created a table,
> there are icons on the rows (of man and women).
> could you please explain how to change\add icons to table rows?
> thanks!
There is nothing to do to have the icon on lines of table. The joined
screenshot shows an example of a simple table made with EcoreTools [1].
The corresponding table description is here [2].
[1] https://www.eclipse.org/ecoretools/
[2]
http://git.eclipse.org/c/ecoretools/org.eclipse.ecoretools.git/tree/org.eclipse.emf.ecoretools.design/description/ecore.odesign#n1195
Laurent Redor - Obeo
Re: How to add icons to Table rows [message #1712936 is a reply to message #1712921] |
Thu, 29 October 2015 13:11 |
Le 29/10/2015 12:33, Yariv Amar a écrit :
> Thank you for the reply.
> So I guess that the icons in your example comes from the ecore tools definition, right?
No, they come from the EMF Ecore edit plugin (org.eclipse.emf.ecore.edit).
> But, what if I'm using Xtext integration?
> I've created a model with xtext and then I use Sirius tables. When i open the table i get diamond shape icons as in the following screenshot
> Do you know how can I change these icons? (somewhere in Xtext, i guess)
You need to generate the edit plugin associated to the metamodel. You
can have a look to [1] Integration with EMF, especially "...From the
derived Ecore model and its generator model, we generated the edit
plug-in (needed by GMF) and added some fancier icons..."
> Thanks again!
[1] https://eclipse.org/Xtext/documentation/308_emf_integration.html
FUDForum. Page generated in 0.04180 seconds
