Update site / downloads down [message #1711668] |
Mon, 19 October 2015 07:42 |
Martin Buchert Messages: 2 Registered: October 2015 |
since Friday, our buckminster builds no longer work. They download the babel translations for Indigo from the 10.0 repository.
However, I noticed that when directly trying to access the "plugin" directory in the browser, the request never completes and an error page appears: http://archive.eclipse.org/technology/babel/update-site/R0.10.0/indigo/plugins/?d
After some digging, I believe this is the error that causes our buckminster build to fail:
Contains: An error occurred while collecting items to be installed
Contains: session context was:(profile=TARGET_DEFINITION:local:1445238544014.target, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Contains: No repository found containing: osgi.bundle,org.eclipse.ant.launching.nl_de,3.7.0.v20120721081147
Contains: Error closing the output stream for org.eclipse.update.feature,org.eclipse.babel.nls_birt_de,3.7.0.v20120721081147 on repository file:/C:/Users/Build.User/jenkins/workspace/Product%20Stable/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool.
java.io.IOException: Error unzipping C:\Users\BUILD~1.USE\AppData\Local\Temp\org.eclipse.babel.nls_birt_de_3.7.0.v201207210811471260154106854386277.jar: Invalid zip file format
at org.eclipse.equinox.internal.p2.core.helpers.FileUtils.unzipFile(FileUtils.java:75)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository$ZippedFolderOutputStream.close(SimpleArtifactRepository.java:193)
at java.io.FilterOutputStream.close(FilterOutputStream.java:160)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository$ArtifactOutputStream.close(SimpleArtifactRepository.java:121)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:276)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:208)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:138)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:708)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.DownloadJob.run(DownloadJob.java:63)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Is that a known problem yet?
Thanks for your input!
Re: Update site / downloads down [message #1726224 is a reply to message #1712390] |
Thu, 10 March 2016 15:39 |
Dmitriy Grintshak Messages: 4 Registered: March 2016 |
I experience the same problem when doing build with Tycho for Helios / v. 0.10.1. The mirror definitions are incorrect. Is the version 0.10.X still supported, or I should migrate to the newer one?
[INFO] Downloading org.eclipse.core.databinding.beans.nl_de
[ERROR] Internal error: java.lang.NullPointerException -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.NullPointerException
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:665)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:590)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:723)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:287)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:267)
at org.eclipse.tycho.p2.maven.repository.MavenMirrorRequest.perform(MavenMirrorRequest.java:100)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:707)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:778)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.getArtifacts(CompositeArtifactRepository.java:341)
at org.eclipse.tycho.p2.target.P2ArtifactDownloadTool.downloadArtifactsToLocalMavenRepository(P2ArtifactDownloadTool.java:55)
at org.eclipse.tycho.p2.target.TargetPlatformImpl.downloadArtifacts(TargetPlatformImpl.java:199)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:124)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:76)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:448)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:425)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:98)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:64)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
... 11 more
[ERROR]
[Updated on: Thu, 10 March 2016 15:42] Report message to a moderator
FUDForum. Page generated in 0.02094 seconds
