Home » Newcomers » Newcomers » [solved] Eclipse (Linux) force GTK2
[solved] Eclipse (Linux) force GTK2 [message #1711538] Fri, 16 October 2015 19:25 Go to next message
Timo Breihals is currently offline Timo BreihalsFriend
I can't find anything on the internet, so I hope I'll get the answer here.
I am using Archlinux with Linux 4.2.3-1 and recently updated to gtk3 3.18.2-1. I was developing on Eclipse Mars 1 Version 4.5.1. So pretty much on the edge of stable I think. I recently started developing with a wildfly Server. After updating my OS, Eclipse failed and wasn't able to be executed properly.
  • Properties Pane couldn't be opened
  • Eclipse can't add Servers (hangs)
  • Significant Marketplace-performance problems
So I have now purged GTK3 with all it's dependencies..... (so alot of my everyday applications). Nevertheless I've GTK2 installed where Eclipse runs flawlessly. So my question is: Can Eclipse be configured to use GTK2 on purpose?
Greetings Timo.
[Updated on: Sat, 17 October 2015 18:48]
Report message to a moderator
Re: Eclipse (Linux) force GTK2 [message #1711546 is a reply to message #1711538] Sat, 17 October 2015 04:17 Go to previous messageGo to next message
Timo,
You can add the following before the VM args in the eclipse.ini
--launcher.GTK_version
2
On 17/10/2015 2:52 AM, Timo Breihals wrote:
> Hello,
> here.
> Greetings Timo.
Re: Eclipse (Linux) force GTK2 [message #1711584 is a reply to message #1711538] Sat, 17 October 2015 18:48 Go to previous messageGo to next message
Thank you. That worked.
icon14.gif  Re: Eclipse (Linux) force GTK2 - "usar eclipse con gtk2" [message #1732254 is a reply to message #1711546] Sat, 14 May 2016 00:06 Go to previous message
juan nambert is currently offline juan nambertFriend
this is the way to start eclipse with gtk2 in this file is eclipse.ini
change
--launcher.defaultVersion or something like that
by
2
-startup
plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.300.v20150602-1417
-product
org.eclipse.epp.package.jee.product
2
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512m
2
optional
openFile
--launcher.appendVmargs
-vmargs
-Dosgi.requiredJavaVersion=1.7
-XX:MaxPermSize=256m
-Xms256m
-Xmx1024m
-Dosgi.configuration.area=@user.home/.config/eclipse-jee
regards Very Happy
Previous Topic:From ocl expression to syntax tree (Search about a tool)
Next Topic:gitignore without breaking workspace
Current Time: Mon Jul 13 14:34:16 GMT 2020
Powered by FUDForum. Page generated in 0.03033 seconds
