Home » Archived » EPP » eclipse.exe and data usage?(excessive data collection)
eclipse.exe and data usage? [message #1711131] Tue, 13 October 2015 07:10 Go to next message
hi,
i've noticed that eclipse.exe is uploading/downloading a lot of data on a daily basis. yesterday was 73 meg up and 15 meg down. i have data usage reporting shutoff. i'm running the juno version of eclipse.
we use verizon for internet and have a 10G monthly limit, so 2G for eclipse is unacceptable.
is this normal? any suggestions welcome.
john
Re: eclipse.exe and data usage? [message #1713916 is a reply to message #1711131] Sun, 08 November 2015 06:23 Go to previous messageGo to next message
I don't know if Eclipse Juno (4.2) ships the usage data collector (UDC). But even if so, you would have to enable it explicitly. It wouldn't send anything in the background. And it would not download anything - just upload.
I guess, you have to look for some other reason, setting or plugin (than the UDC) that creates the traffic you mention.
[Updated on: Sun, 08 November 2015 09:56] by Moderator
Re: eclipse.exe and data usage? [message #1713923 is a reply to message #1711131] Sun, 08 November 2015 09:54 Go to previous message
On 10/13/2015 9:06 AM, john cummings wrote:
> hi,
> eclipse.
> john
Use wireshark and try and figure where the packets are going. might help you figure out what plugin(s) are causing the issue.
Also, make sure you turn OFF automatic check for updates. it might be waking up and doing a bunch of checks daily.
Previous Topic:[aeri] [ann] Problem Dashboards per Project
Next Topic:[aeri] System Maintenance from 21-22 November
Current Time: Sat Mar 22 06:17:46 EDT 2025
Powered by FUDForum. Page generated in 0.03772 seconds
