Home » Archived » Gyrex » workspace folder is huge
workspace folder is huge [message #1710663] Thu, 08 October 2015 09:16 Go to next message
Sean Zhang is currently offline Sean ZhangFriend
Hi All,
I have just run the server with production configuration for about half month, and today I found that the size of the workspace size was about 45G.
Specially for following two folders:
/data/mumunion_gyrex/workspace/zookeeper/version-2
This folder includes some snapshot files about jobs.
/data/mumunion_gyrex/workspace/zookeeper/logs/version-2
This folder includes logs for jobs.
Can I change the storage way for that snapshot files, such as mongo or mysql?
Or, Can I customize the storage path for the snapshot files?
Sean
Study every day, and love every day!
Re: workspace folder is huge [message #1710665 is a reply to message #1710663] Thu, 08 October 2015 09:23 Go to previous messageGo to next message
Jürgen Albert is currently offline Jürgen AlbertFriend
Are u using the embedded zookeeper in production mode?
Re: workspace folder is huge [message #1710696 is a reply to message #1710663] Thu, 08 October 2015 13:14 Go to previous messageGo to next message
Gunnar Wagenknecht is currently offline Gunnar WagenknechtFriend
Hi Sean,
That looks like the Zookeeper storage files. The embedded Zookeeper is
only started in development mode. However, the built-in cleanup only
happens during server start/stop.
Quick question, have you setup a separate Zookeeper cluster?
https://wiki.eclipse.org/Gyrex/Administrator_Guide#Preparing_for_Production_Deployment
Zookeeper needs some regular clean-up of its data directory. That
usually happens via a cron script after/as part of the backup story.
http://zookeeper.apache.org/doc/r3.3.1/zookeeperAdmin.html#Ongoing+Data+Directory+Cleanup
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Re: workspace folder is huge [message #1710753 is a reply to message #1710665] Fri, 09 October 2015 01:41 Go to previous messageGo to next message
Yes
Jürgen Albert wrote on Thu, 08 October 2015 09:23
Re: workspace folder is huge [message #1710755 is a reply to message #1710753] Fri, 09 October 2015 01:51 Go to previous messageGo to next message
My business volume is still small, and currently it run on one cloud server, so I use the embedded zookeeper right now. I will follow the production deploy guide to setup a cloud to support the business if the it grows quickly.
Re: workspace folder is huge [message #1710763 is a reply to message #1710755] Fri, 09 October 2015 05:35 Go to previous message
> it grows quickly.
That's fine. You can also run standalone if you like.
For now, please setup a cron job, that regulary purges old Zookeeper
transaction logs and snapshots.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
Previous Topic:custom node tags
Next Topic:How to setup the configuration in program?
Current Time: Fri Jul 01 03:56:31 GMT 2022
Powered by FUDForum. Page generated in 0.02653 seconds
