Re: [CDO] Automatic committing turned on and automatic locking [message #1710662 is a reply to message #1710610] |
Thu, 08 October 2015 09:12 |
Am 07.10.2015 um 23:29 schrieb Stephane Fournier:
> Hi there,
> I've just have a look at the nice documentation that Eike blogged about and I have found highly valuable informations
> and especially this point it is possible to turn on automatic committing.
> Hence, I'm looking where is this option, I cannot find it on transaction.options() or session.options :(
> It could be done through a transactionHandler but I did not find an inherited class with the name
> AutomaticCommitTransactionHandler...
> Does anyone have an idea ?
Hm, I thought I provided a small utility class but apparently I did some experiment in CDOCheckoutImpl. That experiment
is currently commented out, but should do the trick:
transaction.addTransactionHandler(new CDODefaultTransactionHandler1()
private Job commitJob = new Job("Commit")
protected IStatus run(IProgressMonitor monitor)
try
synchronized (transaction)
if (transaction.isDirty())
transaction.commit();
catch (Throwable ex)
ex.printStackTrace();
return Status.OK_STATUS;
public void modifyingObject(CDOTransaction transaction, CDOObject object, CDOFeatureDelta featureChange)
commitJob.schedule(200);
I hope that helps.
> Regarding automatic locking, is it right to use the CDOAutoLocker class ?
Yes, that's the one.
> Thanks in advance for your help.
You're welcome ;-)
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO] Automatic committing turned on and automatic locking [message #1710862 is a reply to message #1710662] |
Fri, 09 October 2015 20:32 |
Stephane fournier Messages: 340 Registered: July 2009 |
Eike,
Thank you for the answer.
Why do you need to schedule the commit after 200ms ? Is it possible to do it directly in modifying method ?
To do the same feature, I'm using an EditingDomain where all model changes are performed through EMF commands (not based on changeRecorder). Hence, in overriding the commandStack I get the transaction from the impacted objects and I commit the transaction when the command completes.
When I read your great documentation, I was wondering what is the best approach in terms of performances in real time context (multiple JVM modifying data at high pace on the same cdo server) ? I do not need undo / redo capabilities.
Waiting for 200ms could be long in real time context
I will test your suggested code to evaluate this approach.
Stephane.
Eike Stepper wrote on Thu, 08 October 2015 05:12Am 07.10.2015 um 23:29 schrieb Stephane Fournier:
> Hi there,
try
I hope that helps.
You're welcome
Cheers
/Eike
Re: [CDO] Automatic committing turned on and automatic locking [message #1710929 is a reply to message #1710862] |
Sun, 11 October 2015 09:40 |
Am 09.10.2015 um 22:32 schrieb Stephane Fournier:
> Eike,
That's not strictly needed. At a minimum you'd want to ensure that the commit does not happen on the UI thread. But if
you fork off a new thread you'd probably don't want to queue up many commit threads if the first one would already
commit all changes together. IIRC a call to CDOTransaction.commit() *always* involves a server round-trip, even if the
transaction is not dirty (that's related to releasing potential locks).
Certainly an optimistic locking strategy. That would probably involve the ability to "replay" the changes in cases of
ConcurrentAccessExceptions.
> Waiting for 200ms could be long in real time context :)
You can decrease or remove the delay.
Cheers
/Eike
> Stephane.
>> > Hi there,
>> informations > and especially this point it is possible to turn on automatic committing.
>> > It could be done through a transactionHandler but I did not find an inherited class with the name >
>> experiment is currently commented out, but should do the trick:
>> @Override
>> try
>> @Override
>> I hope that helps.
>> You're welcome ;)
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
Cheers
/Eike
FUDForum. Page generated in 0.03136 seconds
