Home » Modeling » EMF » [CDO] Usage of setStrongReferencePolicy
[CDO] Usage of setStrongReferencePolicy [message #1710519] |
Wed, 07 October 2015 09:41 |
In the javadoc of
CDOView.Options.setStrongReferencePolicy(CDOAdapterPolicy), we can read
that:
Sets the reference type to be used when an adapter is used to an object.
When CDOView.setStrongReference(CDOAdapterPolicy.ALL) is used, it is
possible that the target object will be GC. In that case, the adapter
will never received notifications. By Default the value is at
CDOAdapterPolicy.ALL.
I feel that CDOAdapterPolicy.NONE provides a GC and not
CDOAdapterPolicy.ALL. Can someone confirm that the javadoc is false?
In our case, with option strongReferencePolicy set to
CDOAdapterPolicy.NONE, after a break of 10 minutes, we have some
EObjects without their original eAdapters. This is not the case with
With option set to CDOAdapterPolicy.NONE, the
CDORevisionCacheNonAuditing "cleans" the softReferences after about 10
minutes (AbstractCDORevisionCache.work(Reference<? extends
InternalCDORevision>).
Laurent Redor - Obeo
Re: [CDO] Usage of setStrongReferencePolicy [message #1710525 is a reply to message #1710519] |
Wed, 07 October 2015 10:08 |
Hi Laurent,
By default a CDOView has the strong reference policy CDOAdapterPolicy.ALL, which creates extra strong references (in
addition to the soft references that the view maintains anyway) to all objects that have adapters, which effectively
prevents these objects from being garbage collected until all adapters are removed (or the policy is changed).
If you set the strong reference policy of a view to CDOAdapterPolicy.NONE (or to any other policy that doesn't create
extra strong references to all adapted objects) objects may end up with only the internal soft references even though
they still have adapters attached. These objects can happen to be garbage collected and when you navigate to them again,
new objects will be created. These new objects will miss the original adapters.
Cheers
/Eike
http://www.esc-net.de
Am 07.10.2015 um 11:41 schrieb Laurent Redor:
> Hello,
> In the javadoc of CDOView.Options.setStrongReferencePolicy(CDOAdapterPolicy), we can read that:
> When CDOView.setStrongReference(CDOAdapterPolicy.ALL) is used, it is possible that the target object will be GC. In
> that case, the adapter will never received notifications. By Default the value is at CDOAdapterPolicy.ALL.
> I feel that CDOAdapterPolicy.NONE provides a GC and not CDOAdapterPolicy.ALL. Can someone confirm that the javadoc is
> false?
> In our case, with option strongReferencePolicy set to CDOAdapterPolicy.NONE, after a break of 10 minutes, we have some
> EObjects without their original eAdapters. This is not the case with CDOAdapterPolicy.ALL.
> With option set to CDOAdapterPolicy.NONE, the CDORevisionCacheNonAuditing "cleans" the softReferences after about 10
> minutes (AbstractCDORevisionCache.work(Reference<? extends InternalCDORevision>).
> Best regards,
Cheers
/Eike
Re: [CDO] Usage of setStrongReferencePolicy [message #1710535 is a reply to message #1710525] |
Wed, 07 October 2015 11:10 |
Thanks Eike for your response.
That confirms that the javadoc should be
When CDOView.setStrongReference(CDOAdapterPolicy.NONE) is used, it is
or
When CDOView.setStrongReference(CDOAdapterPolicy.ALL) is not used, it is
Le 07/10/2015 12:08, Eike Stepper a écrit :
> Hi Laurent,
> CDOAdapterPolicy.ALL, which creates extra strong references (in addition
> that have adapters, which effectively prevents these objects from being
> changed).
> CDOAdapterPolicy.NONE (or to any other policy that doesn't create extra
> the internal soft references even though they still have adapters
> navigate to them again, new objects will be created. These new objects
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hello,
>> In the javadoc of
>> read that:
>> Best regards,
Re: [CDO] Usage of setStrongReferencePolicy [message #1710568 is a reply to message #1710535] |
Wed, 07 October 2015 14:55 |
Am 07.10.2015 um 13:10 schrieb Laurent Redor:
> When CDOView.setStrongReference(CDOAdapterPolicy.NONE) is used, it is possible that the target object will be GC.
> or
> When CDOView.setStrongReference(CDOAdapterPolicy.ALL) is not used, it is possible that the target object will be GC.
You're right. I've changed the docs. Thanks for the hint!
Cheers
/Eike
>> Hi Laurent,
>> changed).
>> Cheers
>> /Eike
>>> Hello,
>>> In the javadoc of
>>> read that:
>>> Best regards,
Cheers
/Eike
Current Time: Sat Apr 20 02:28:29 GMT 2024
Powered by FUDForum. Page generated in 0.03464 seconds
