Home » Language IDEs » C / C++ IDE (CDT) » Code Analysis(Error on "far" directive to force far call)
Code Analysis [message #1709808] Thu, 01 October 2015 09:21 Go to next message
Gilbert Bombrun is currently offline Gilbert BombrunFriend
I am using one of a TI compilers for one of their DSP.
In Eclipse Kepler, the "far" directive before a function or a variable generates an error in the editor :
far int function (int)
far Var var;
How could I notify to eclipse that this word is not an error
Same thing with the "interrupt" directive :
interrupt void timer1_srv (void)
Many thanks in advance for your suggestions.
Re: Code Analysis [message #1710001 is a reply to message #1709808] Fri, 02 October 2015 14:31 Go to previous messageGo to next message
Hello Gilbert,
If it is just for the editor and code analysis, you can try to define "far" to nothing in the projects path and symbols settings
Re: Code Analysis [message #1710030 is a reply to message #1709808] Fri, 02 October 2015 18:38 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
Click 'Properties' on the project directory, go to C/C++ General, Paths and Symbols.
Select the #Symbols page then click Add. Add a symbol, e.g. __ECLIPSE__ and set a value for it e.g. 1.
Then, add to your code conditional macros:
#if defined(__ECLIPSE__)
#define far
#endif
Eclipse parser will ignore the attributes, but the real compiler will see it.
I'm using a similar method to change code for Doxygen, by defining __DOXYGEN__ in the Doxygen control file.
Tauno Voipio
Re: Code Analysis [message #1710164 is a reply to message #1710030] Mon, 05 October 2015 07:20 Go to previous message
Hello Tauno Voipio,
Thank you very much for your help !!!
It's now working properly. I've no more "bug" flying in the vertical ruler. Smile
With best regards,
Gilbert.
Previous Topic:Start a new project/code
Next Topic:breakpoints ignored
Current Time: Fri Sep 20 13:59:43 GMT 2024
Powered by FUDForum. Page generated in 0.04099 seconds
