Home » Modeling » TMF (Xtext) » cross-project references not resolved in standalone mode
cross-project references not resolved in standalone mode [message #1709708] Wed, 30 September 2015 13:46 Go to next message
Hans-Peter Bantle is currently offline Hans-Peter BantleFriend
I have splitted my model file into multiple files and put them into different projects. Once I have configured the project dependencies, this is working perfectly fine in Eclipse:
index.php/fa/23401/0/
Btw, I'm using the DSL from the Extended-15-Minutes-Tutorial: https://eclipse.org/Xtext/documentation/103_domainmodelnextsteps.html
And I have attached the actual DSL: domainmodel_dsl.zip
as well as my project files: my.project.zip
Now I'm trying to build my project with gradle (build.gradle scripts are included with the project files). But when the second project gets validated, I always end up with following error:
Starting validation for input: 'blog.dmodel'
ERROR:Couldn't resolve reference to Type 'String'. (file:/C:/dev/runtime-EclipseXtext/my.project.blog/src/main/java/blog.dmodel line : 6)
ERROR:Couldn't resolve reference to Entity 'HasAuthor'. (file:/C:/dev/runtime-EclipseXtext/my.project.blog/src/main/java/blog.dmodel line : 10)
ERROR:Couldn't resolve reference to Type 'String'. (file:/C:/dev/runtime-EclipseXtext/my.project.blog/src/main/java/blog.dmodel line : 11)
ERROR:Couldn't resolve reference to Type 'String'. (file:/C:/dev/runtime-EclipseXtext/my.project.blog/src/main/java/blog.dmodel line : 12)
ERROR:Couldn't resolve reference to Entity 'HasAuthor'. (file:/C:/dev/runtime-EclipseXtext/my.project.blog/src/main/java/blog.dmodel line : 16)
ERROR:Couldn't resolve reference to Type 'String'. (file:/C:/dev/runtime-EclipseXtext/my.project.blog/src/main/java/blog.dmodel line : 17)
:my.project.blog:xtextGenerate FAILED
Has anyone experienced a similar problem and found a solution for this? Any kind of help is very much appreciated. Thanks.
Re: cross-project references not resolved in standalone mode [message #1709713 is a reply to message #1709708] Wed, 30 September 2015 14:04 Go to previous messageGo to next message
Stefan Oehme is currently offline Stefan OehmeFriend
The xtextTooling configuration is only meant for dependencies of the Xtext generator itself (i.e. you add your language implementation to that).
For dependencies between projects, please use the usual compile/testCompile configurations.
Re: cross-project references not resolved in standalone mode [message #1709717 is a reply to message #1709713] Wed, 30 September 2015 14:14 Go to previous messageGo to next message
Thanks for your reply. I just modified the build.gradle file in project my.project.blog and changed the dependency configuration to:
dependencies {
   compile project(path: ':my.project.common')
Of course, this works fine for compile dependencies, but unfortunately not for dsl references. From my point of view, the import statement in blog.dmodel does not get resolved.
The error actually occurs in task xtextGenerate, as you can see in the above error message.
Re: cross-project references not resolved in standalone mode [message #1709741 is a reply to message #1709717] Wed, 30 September 2015 16:09 Go to previous messageGo to next message
That's because your dmodel files are not in the .jar. You should put them in src/main/resources or add src/main/java to the list of resource folders.
Re: cross-project references not resolved in standalone mode [message #1709800 is a reply to message #1709741] Thu, 01 October 2015 07:49 Go to previous messageGo to next message
Adding src/main/java to the list of resource folders solved the problem. Thanks a lot.
Re: cross-project references not resolved in standalone mode [message #1709803 is a reply to message #1709800] Thu, 01 October 2015 07:51 Go to previous messageGo to next message
Have a look at you jar contents, though. Adding src/main/java as a resource might lead to other source files being put in the jar, too. So you might need to add some exclude rules to it.
Re: cross-project references not resolved in standalone mode [message #1746452 is a reply to message #1709803] Sat, 29 October 2016 10:03 Go to previous messageGo to next message
Edilberto Castellanos is currently offline Edilberto CastellanosFriend
xtext cross-project references not resolved in standalone mode during maven compilation. I have enhanced a bit herolanguage to model hero idols and validate the resolution of cross-project references and it runs as eclipse projects, taken into account maven dependencies, but when running as a maven install it fails to resolve them.
I upload the samples,
any help would be appreciated.
thanks.
  • Attachment: heroplus.zip
    (Size: 4.86MB, Downloaded 138 times)
  • Attachment: sample.zip
    (Size: 12.21KB, Downloaded 133 times)
Re: cross-project references not resolved in standalone mode [message #1746467 is a reply to message #1746452] Sun, 30 October 2016 08:27 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
<classPathLookupFilter>.</classPathLookupFilter>
is bad, that regex will match barely nothing
Twitter : @chrdietrich
Re: cross-project references not resolved in standalone mode [message #1746478 is a reply to message #1746467] Sun, 30 October 2016 15:01 Go to previous messageGo to next message
Thank you Cristian, I had been fighting against the workflow and ResourceProviders customization, looking at wrong places.
A lot of thanks.
Re: cross-project references not resolved in standalone mode [message #1779840 is a reply to message #1746478] Sun, 14 January 2018 12:52 Go to previous messageGo to next message
Martin Trummer is currently offline Martin TrummerFriend
I also have a problem with simple cross-references between 2 java modules in a gradle build.
Here is my DSL-project :
Relevant parts of
X2Dsl.xtext
grammar com.tmtron.ex.xtext2.dsl.X2Dsl with org.eclipse.xtext.xbase.annotations.XbaseWithAnnotations
generate x2Dsl "http://www.example.com/ex/xtext2/dsl/X2Dsl"
x2Model:
	importSection=XImportSection?
    elements+=AbstractElement*
AbstractElement:
    PackageDeclaration | DomainObject | UseCase;
PackageDeclaration:
    'package' name=QualifiedName '{'
DomainObject:
	'do' name=ValidID;
UseCase:
	'uc' name=ValidID 'do=' doRef=[DomainObject|ValidID];
The Inferrer-code:
X2DslJvmModelInferrer.xtend
	def dispatch void infer(DomainObject domainObject, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
 		acceptor.accept(domainObject.toClass(domainObject.fullyQualifiedName)) [
 			documentation = "generated from the domain model"
	def dispatch void infer(UseCase useCase, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
 		acceptor.accept(useCase.toClass(useCase.fullyQualifiedName)) [
 			documentation = "use-case generated from the domain model"
 			val doClassRef = typeRef(useCase.doRef.fullyQualifiedName.toString)
 			members += useCase.doRef.toField(useCase.doRef.name.toFirstLower, doClassRef) => [
 				visibility = JvmVisibility.PUBLIC
The DSL is used in this project: dsl-usage
which uses gradle and has 2 java-modules.
Domain project
domain has a simple model, which defines a User DomainObject: model.x2dsl
package com.tmtron.test.domain {
	do User
the gradle build file build.gradle
makes sure that the model.x2dsl file is included in the jar:
sourceSets.main.resources.srcDirs += ["src/main/java"]
Interactors project
The interactors module
has a dependency on the domain module. Gradle build file: interactors/build.gradle
dependencies {
	implementation project(':domain')
and in the Interactors model interactorModel.x2dsl
, I want to reference the User domain object like this:
import com.tmtron.test.domain.User
package com.tmtron.text {
	uc GetUserName do=User
	uc SetUserName do=User
but the build fails (see log output)
with this error:
Error calling inferrer
ERROR:User cannot be resolved. (file:/builds/xtext2/dsl-usage/interactors/src/main/java/com/tmtron/ex/xtext2/usage/interactorModel.x2dsl line : 5 column : 20)
ERROR:User cannot be resolved. (file:/builds/xtext2/dsl-usage/interactors/src/main/java/com/tmtron/ex/xtext2/usage/interactorModel.x2dsl line : 6 column : 20)
Maybe the problem is in my inferrer?
I am not sure if this reference type is correct:
[Updated on: Sun, 04 September 2022 06:54]
Report message to a moderator
Re: cross-project references not resolved in standalone mode [message #1779841 is a reply to message #1779840] Sun, 14 January 2018 13:08 Go to previous messageGo to next message
you have to list all dsl with their standalonesetups here: https://gitlab.com/xtext2/dsl-usage/blob/master/build.gradle
Re: cross-project references not resolved in standalone mode [message #1779842 is a reply to message #1779841] Sun, 14 January 2018 13:14 Go to previous messageGo to next message
Christian Dietrich wrote on Sun, 14 January 2018 13:08
Thanks for the fast rely. But I am not sure what you mean.
I only have one DSL and it is registered in the subprojects block: so it will be registered for both modules (domain and interactors), right?
Re: cross-project references not resolved in standalone mode [message #1779843 is a reply to message #1779842] Sun, 14 January 2018 13:42 Go to previous messageGo to next message
hmmm again its seems to be a bad idea to highjack the same thread for different things ....
i dont know the gradle plugin you use and the configuration "implementation"
thus i tried only this
dependencies {
compile project(':domain')
xtext {
version = '2.13.0'
generateXtext.classpath = configurations.compile
Re: cross-project references not resolved in standalone mode [message #1779844 is a reply to message #1779843] Sun, 14 January 2018 14:47 Go to previous message
Christian Dietrich wrote on Sun, 14 January 2018 13:42
Sorry, I thought this is the same issue as the original question. Thus I've asked it here.
Thanks a lot - this line helped me:
I was not aware that we need to set the classpath - I couldn't find this in the docs of the xtext-builder gradle plugin
The Java Library Plugin is an extension to the Java plugin and allows to specify which dependencies are only needed for the implementation and which are also needed by the consumer (api dependencies will be transitively resolved).
The following works for me (in interactors/build.gradle):
dependencies {
generateXtext.classpath = configurations.runtimeClasspath
Previous Topic:How to generate API document of DSL?
Next Topic:Code assist for DataType rules
Current Time: Tue Apr 16 22:32:47 GMT 2024
Powered by FUDForum. Page generated in 1.89088 seconds
