Home » Eclipse Projects » Sirius » Cell inside a table with multiline text
Cell inside a table with multiline text [message #1709262] Fri, 25 September 2015 12:18 Go to next message
Max DoeFriend
I created an Edition Table Description. My purpose is to have a cell with multilines text in it.
I read the tables documentation but I cannot figure out what is meant with
"the property edited with the cell is declared as multi-line".
I have an 'EString Attribute' called body inside the ecore class diagram. In the odesign file I set this 'Attribute' inside the 'Label Edit' with a 'set Operation'. That allows me to edit the cell but all text appears in one line.
Help would be much appreciated. Thanks!
Re: Cell inside a table with multiline text [message #1709280 is a reply to message #1709262] Fri, 25 September 2015 14:54 Go to previous messageGo to next message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
Le 25/09/2015 15:43, Max Doe a écrit :
Hi.
> with "the property edited with the cell is declared as multi-line".
The "multi-line" property is set in your metamodel's .genmodel: in the
properties of the EAttribute, inside the "Edit" category, change the
"Property multi-line" to "true" (and regenera/re-deploy your metamodel).
IIRC, you will not get a multi-line cell directly inside the table, but
when the cell is selected, a "[...]" button will open a multi-line
dialog to edit the value.
Pierre-Charles
Pierre-Charles David - Obeo
Re: Cell inside a table with multiline text [message #1709461 is a reply to message #1709280] Mon, 28 September 2015 15:11 Go to previous message
Max DoeFriend
Thank you!
Changed and regenerated.
The button show up inside the "Properties" tab. Demonstrated in the Picture below.
index.php/fa/23381/0/
I'm facing two problems now.
I did not get the "up/down arrow" as described in the documentation.
The documentation also describes:
Under all systems, to finish the edition of a multi-line text, you need to use Ctrl+Return. Hitting Return will simply add a new line.
This functionalies only works if there is only one line "Feature".
Feature Name: body (work)
Feature Name: * (fail)
I hope you could help me with this issues too.
Previous Topic:Coloring shapes depending on associated rgb value
Next Topic:How to create with JAXB or EMF the XMI files from a created sirius editor.
Current Time: Tue Mar 02 15:10:31 GMT 2021
Powered by FUDForum. Page generated in 0.01626 seconds
