Home » Eclipse Projects » Requirements Modeling Framework  » ID-Generator auto-numbering.
ID-Generator auto-numbering. [message #1709261] Fri, 25 September 2015 12:11 Go to next message
Max Russell is currently offline Max RussellFriend
Member
I have setup an ID-Generator presentation, but don't see it being used against requirements. I'm following the instructions in the help and also the fmstudio.pdf - what steps might I be missing?
Also, I note that the pdf states:
"Currently, the presentation does not check whether duplicate
IDs exist!"
Is this still true? When my requirements base increases, this could be of concern.
Re: ID-Generator auto-numbering. [message #1709376 is a reply to message #1709261] Mon, 28 September 2015 06:12 Go to previous messageGo to next message
Michael Jastram is currently offline Michael JastramFriend
Hi Max,
Carefully check the following: (1) The ID-Generator is associated with a DatatypeDefinition; (2) There must be an Attribute using that DatatypeDefinition; (3) The Attribute belongs to a SpecObjectType; (4) Only SpecObjects using that SpecObjectType will receive IDs.
> "Currently, the presentation does not check whether duplicate IDs exist!"
The Generator simply increments a counter and assigns IDs. If you are working in a team environment, this could lead to duplicates, and this is not checked. Checking this is not that difficult, but someone has to implement it. If this is a concern to you, you should not use it (or fix it. Smile).
Best,
- Michael
Re: ID-Generator auto-numbering. [message #1709419 is a reply to message #1709261] Mon, 28 September 2015 10:52 Go to previous messageGo to next message
Member
Yes, I have this setup - but I'm not seeing my numbering used:
index.php/fa/23377/0/
index.php/fa/23378/0/
Re: ID-Generator auto-numbering. [message #1709483 is a reply to message #1709419] Mon, 28 September 2015 20:03 Go to previous messageGo to next message
What Datatype are you using for RequirementType.ID?
Re: ID-Generator auto-numbering. [message #1709548 is a reply to message #1709483] Tue, 29 September 2015 08:41 Go to previous messageGo to next message
Member
I thought I had set it correctly:
index.php/fa/23383/0/
Re: ID-Generator auto-numbering. [message #1709557 is a reply to message #1709548] Tue, 29 September 2015 09:56 Go to previous messageGo to next message
Hi Max,
From the screenshot I cannot see what I am looking for: You need to select "ID" (the Attribute of "Requirement Type". Then you would see in the lower pane, which **Datatype** is assinged. If it is T_String32k (as I suspect), then you'd have to change it to T_ID.
But maybe I am on the wrong track.
Best,
- Michael
Re: ID-Generator auto-numbering. [message #1709560 is a reply to message #1709557] Tue, 29 September 2015 10:05 Go to previous message
Member
Bingo! Thank you very much. I had the SpecType (SpecObject) and the datatype T_ID but hadn't applied the T_ID as the SpecObject attribute type for string, as you suggested!
Happily numbering away now!
Previous Topic:Creating SpecHierarchy Programmatically and Save to .reqif file
Next Topic:What datatype required for Glossary?
Current Time: Sat Mar 06 18:21:07 GMT 2021
Powered by FUDForum. Page generated in 0.02574 seconds
