Home » Eclipse Projects » BPMN 2.0 Modeler » Bpmn2 diagram editor - Properties, constraint field is not showing up(Bpmn2 diagram editor - Properties, constraint field is not showing up)
Bpmn2 diagram editor - Properties, constraint field is not showing up [message #1709220] Fri, 25 September 2015 00:09 Go to next message
I have just started learning jBPM and creating some sample programs.
1. I have eclipse luna and installed the JBoss Developer Studio Integration Stack 8.0.3.GA
index.php/fa/23352/0/
2. During installation I was prompted to enter the login details for fisheye.codehaus.org, I searched in the internet, but couldn't find any relevant information and hence I just cancelled it. Even though the installation was completed.
index.php/fa/23353/0/
3. Then I created a simple jBPM project.
index.php/fa/23354/0/
4. But I am not getting the Constraint field in the Properties tab of the exclusive gateway element. Also I am not understanding how to set Process level variable so that a particular branch will be evaluated based on the variable value.
index.php/fa/23355/0/
Can you please help me out? I spent a lot of time in debugging and searching in the internet, but couldn't find any answer!
Thanks and regards
Re: Bpmn2 diagram editor - Properties, constraint field is not showing up [message #1709324 is a reply to message #1709220] Sat, 26 September 2015 07:02 Go to previous message
Well, I uninstalled jBPM6 and installed jBPM5 and the issue is resolved.
Previous Topic:BIRT Publishing
Next Topic:Using @Autowired in User Task > On Exit Script to call Spring Service
Current Time: Sun Nov 02 09:53:15 EST 2025
Powered by FUDForum. Page generated in 0.07809 seconds
