Home » Modeling » Papyrus » Deployment Diagram: how to connect elements? (deployment diagram misses communication path)
Deployment Diagram: how to connect elements? [message #1708635] Fri, 18 September 2015 09:00 Go to next message
Anatoly Shirokov is currently offline Anatoly ShirokovFriend
Hello!
I am a newcomer. How to connect elements in a deployment diagram with the uml communication path?
Thanks in advance,
Anatoly Shirokov
Re: Deployment Diagram: how to connect elements? [message #1708708 is a reply to message #1708635] Sat, 19 September 2015 05:52 Go to previous messageGo to next message
Ri Fr is currently offline Ri FrFriend
Looks like it's been fixed via Bug 361106 , but I just updated Papyrus and it shows the same problem! Cannot draw a Link between Nodes. HELP!
[Updated on: Sat, 19 September 2015 06:18]
Report message to a moderator
Re: Deployment Diagram: how to connect elements? [message #1711140 is a reply to message #1708708] Tue, 13 October 2015 12:17 Go to previous messageGo to next message
Jens Bürger is currently offline Jens BürgerFriend
Member
At least in Eclipse Mars .1 / Papyrus 1.1.2, this is fixed. I just checked.
[Updated on: Tue, 13 October 2015 12:17]
Re: Deployment Diagram: how to connect elements? [message #1711772 is a reply to message #1711140] Mon, 19 October 2015 14:48 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Mars.1 / Papyrus 1.1.2 should indeed fix the issue. It has been officially released on October 2nd
Camille
Camille Letavernier
Re: Deployment Diagram: how to connect elements? [message #1711805 is a reply to message #1711772] Mon, 19 October 2015 20:39 Go to previous message
Stephen Blackwell is currently offline Stephen BlackwellFriend
I reported this problem 4 years ago in https://bugs.eclipse.org/bugs/show_bug.cgi?id=349324 which is still open.
Bug 361106 appears to be a duplicate or at least it is very similar.
Previous Topic:Compare/ Merge tool for Papyrus
Next Topic:Errors when opening a Mars model in Luna
Current Time: Thu Sep 24 10:36:52 GMT 2020
Powered by FUDForum. Page generated in 0.01541 seconds
