Home » Eclipse Projects » Nebula » XYGraph - how to draw data points with no connecting line?(Given a Nebula XYGraph trace, how can I display the data points only and not the connecting line?)
XYGraph - how to draw data points with no connecting line? [message #1708457] Wed, 16 September 2015 13:43 Go to next message
Hallo,
I am using Eclipse Nebula XYGraph for a Scientific Project.
In my next graph I will need to display data points only and not the connecting line.
index.php/fa/23287/0/
I tried setting the line width to zero (0), but this is not working.
trace.setLineWidth(0);
Any suggestion ?
        xyGraph = new XYGraph();
        xyGraph.primaryXAxis.setShowMajorGrid(true);
        xyGraph.primaryYAxis.setShowMajorGrid(true);
        xyGraph.setBackgroundColor(ColorConstants.white);
        CircularBufferDataProvider traceDataProvider = new CircularBufferDataProvider(false);
        traceDataProvider.setBufferSize(1000);
        for(Node node : resultList){
    		double x = node.getX();
    		double y = node.getX();
    		// add data point
        	traceDataProvider.addSample(new Sample(x, y));
        // create the trace
        Trace trace = new Trace("Trace1-XY Plot", xyGraph.primaryXAxis, xyGraph.primaryYAxis, traceDataProvider);
        // set trace property
        trace.setPointStyle(PointStyle.XCROSS);
        // How to NOT display the connecting line?
        // add the trace to xyGraph
        xyGraph.addTrace(trace);
Thanks in advance
  • Attachment: scr.png
    (Size: 47.72KB, Downloaded 1042 times)
Re: XYGraph - how to draw data points with no connecting line? [message #1708676 is a reply to message #1708457] Fri, 18 September 2015 11:14 Go to previous messageGo to next message
This should work:
trace.setTraceType(TraceType.POINT);
Re: XYGraph - how to draw data points with no connecting line? [message #1708833 is a reply to message #1708676] Mon, 21 September 2015 11:40 Go to previous message
Max,
It works. Thank you very much!
Kind Regards
Previous Topic:XYGraph - suggested way for user interaction
Next Topic:Nebula grid GridItem.setForeground(color) not working
Current Time: Mon May 19 05:30:24 EDT 2025
Powered by FUDForum. Page generated in 0.04073 seconds
