Home » Modeling » Papyrus » Who uses Sequence Diagrams?(are there positive statements about the application of Sequence Diagrams?)
Who uses Sequence Diagrams? [message #1708199] Mon, 14 September 2015 15:04 Go to next message
Rolf Schumacher is currently offline Rolf SchumacherFriend
Member
Given the forum message https://www.eclipse.org/forums/index.php/mv/tree/1070098/#page_top
I wonder if anybody uses Sequence Diagrams to their success.
Where can I read about the Papyrus implementations status of UML2.5?
Any comment welcome.
Re: Who uses Sequence Diagrams? [message #1708256 is a reply to message #1708199] Tue, 15 September 2015 05:22 Go to previous messageGo to next message
Tomas Sandkvist is currently offline Tomas SandkvistFriend
I use sequence diagrams extensively, and have not experienced these problems.
But....
I have not upgraded to the Mars version because of a lot of other stuff that no longer work as they should, so I'm still at Luna SR1a. So if this is also a Mars-related issue it is good to know.
Tomas Sandkvist
Re: Who uses Sequence Diagrams? [message #1708300 is a reply to message #1708256] Tue, 15 September 2015 09:24 Go to previous messageGo to next message
Member
That is good news, Tomas, thank you.
Yes, you are right: I am running Papyrus 1.1 on Mars.
Which means that these problems are only issues abut functionality that already has worked and which - hopefully in near future - will get repaired.
I feared that these UML features are not implemented yet - and lucky me - I was wrong: just wait for issues to be solved or turn back to Luna.
I tried to find the change management system for Papyrus, I read the name Bugzilla, but I did not find the content. Is that an open one? Or: can I apply to read it?
Rolf
p.s. may be a bunch of users can form an aceptance test team prior to release 1.1.1 or 1.2.
Re: Who uses Sequence Diagrams? [message #1708397 is a reply to message #1708300] Wed, 16 September 2015 09:15 Go to previous messageGo to next message
Ri Fr is currently offline Ri FrFriend
I have the same issue on Mars and it's a problem as I use Sequence Diagrams quite a lot. I assume a bug report has been filed, otherwise I'll be glad to do it...
Re: Who uses Sequence Diagrams? [message #1708411 is a reply to message #1708397] Wed, 16 September 2015 11:24 Go to previous messageGo to next message
Thomas Wiman is currently offline Thomas WimanFriend
Member
I have also got the same problem in Papyrus 1.1.1 on Mars.
There is already a bug filed in bugzilla about this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=473584.
Thomas
Thomas Wiman
MetaModelAgent Product Manager
Re: Who uses Sequence Diagrams? [message #1708442 is a reply to message #1708411] Wed, 16 September 2015 14:18 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Thanks for reporting the issues.
Bug 473584 and Bug 470059 have been fixed on Mars & Master. The fixes will be available in Mars SR1 (Papyrus 1.1.2)
Camille
Camille Letavernier
Re: Who uses Sequence Diagrams? [message #1708483 is a reply to message #1708442] Thu, 17 September 2015 02:39 Go to previous message
Hello Camille and thanks for your helpful posts! I submitted a bug report (477415) for inability to use Notes, ovals, texts etc. on any diagram except timing diagram (at least on my install I have this problem). Do you know if this issue (if it's a confirmed bug) will be fixed on 1.1.2? Any idea on release date? Cheers
Previous Topic:First steps Sequence Diagrams failed
Next Topic:UML Attributes vs. SYSML Properties
Current Time: Thu Jan 28 02:12:34 GMT 2021
Powered by FUDForum. Page generated in 0.01875 seconds
