Home » Eclipse Projects » RCP Testing Tool » Launching the AUT
Launching the AUT [message #1708090] Sat, 12 September 2015 13:03 Go to next message
I'm investigating the use of RCPTT for my Eclipse project CDO. CDO does not define its own product, it's more a set of
plugins that run in any product. Normally for debugging and testing I launch a runtime workbench with the
"org.eclipse.platform.ide" product and my plugins deployed.
I was hoping to be able to use a normal Eclipse Application launch with the RCPTT runtime deployed at least to record
the tests. But it appears to me that I'm required to create a custom product configuration and export it to the
filesystem before I can even define an AUT launch. Is that correct or am I missing something?
Cheers
/Eike
http://www.esc-net.de
Re: Launching the AUT [message #1708117 is a reply to message #1708090] Sun, 13 September 2015 21:19 Go to previous messageGo to next message
Hi Eike,
Let me please reproduce it with CDO Project and come back to you later tonight.
Kind regards,
Ulyana.
Re: Launching the AUT [message #1708127 is a reply to message #1708117] Mon, 14 September 2015 02:04 Go to previous messageGo to next message
Am 14.09.2015 um 03:19 schrieb Ulyana Skorokhodova:
> Hi Eike,
That's awesome. Thank you!
Please note that there's a functional Oomph setup available for the CDO project (in fact I've originally invented the
Oomph technology to support my CDO contributors ;-) ), so after a few clicks in the Eclipse Installer you should quickly
have the exact same workspace that we CDO comitters use. Let me know if you need assistance...
Cheers
/Eike
Re: Launching the AUT [message #1708532 is a reply to message #1708117] Thu, 17 September 2015 06:22 Go to previous messageGo to next message
Hi Ulyana,
Did you already have the chance to develop a more detailed opinion on this issue?
Cheers
/Eike
> Hi Eike,
> Kind regards,
> Ulyana.
Re: Launching the AUT [message #1708788 is a reply to message #1708532] Mon, 21 September 2015 04:53 Go to previous message
Hi Eike,
Could you please try the following:
1) Install RCPTT into Eclipse Mars from an update site;
2) Checkout your CDO sources and create Eclipse Application launch configuration as you would normally do;
3) In Run->Run configurations dialog find an 'Eclipse Application under Test' launch configuration type, create a new one and on launch configuration property page select your existing Eclipse Application launch configuration. If you switch to RCPTT perspective then, you should be able to see your AUT in Applications view and launch it.
It should work ok.
Kind regards,
Ulyana.
Previous Topic:How to launch the AUT maximised?
Next Topic:No RCPTT Test cases found pop up displayed when running a simple Java Class in Eclipse
Current Time: Thu Jul 17 20:12:54 EDT 2025
Powered by FUDForum. Page generated in 0.06834 seconds
