SWT program doesn't run [message #1708017] |
Fri, 11 September 2015 13:12 |
Amritansh Singh Messages: 1 Registered: September 2015 |
Hi, here is the code which I have been trying to run
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.ModifyEvent;
import org.eclipse.swt.events.ModifyListener;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class TemperatureConverter {
Display display = new Display();
Shell shell = new Shell(display);
Label fahrenheitLabel;
Label celsiusLabel;
Label MessageLabel;
Text fahrenheitValue;
Text celsiusValue;
public TemperatureConverter() {
shell.setText("Temperature Converter");
shell.setLayout(new RowLayout());
fahrenheitLabel = new Label(shell, SWT.NONE);
fahrenheitLabel.setText("Fahrenheit: ");
fahrenheitValue = new Text(shell, SWT.SINGLE | SWT.BORDER);
celsiusLabel = new Label(shell, SWT.NONE);
celsiusLabel.setText("Celsius: ");
celsiusValue = new Text(shell, SWT.SINGLE | SWT.BORDER);
MessageLabel = new Label(shell, SWT.BORDER);
GridData griddata = new GridData(GridData.FILL_BOTH);
griddata.horizontalSpan = 4;
MessageLabel.setLayoutData(griddata);
ModifyListener listener = new ModifyListener() {
public void modifyText(ModifyEvent E) {
ValueChanged((Text) E.widget);
fahrenheitValue.addModifyListener(listener);
celsiusValue.addModifyListener(listener);
shell.setBounds(40, 30, 500, 600);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
public void ValueChanged(Text text){
if(!text.isFocusControl())
return;
if(text == fahrenheitValue){
try{
double fvalue = Double.parseDouble(text.getText());
double cvalue = (fvalue - 32) / 1.8;
celsiusValue.setText(Double.toString(cvalue));
MessageLabel.setText("Conversion Performer Successfully.");
} catch(NumberFormatException e){
celsiusValue.setText(" ");
MessageLabel.setText("Invalid Number Format " + text.getText());
} else {
try{
Double cvalue = Double.parseDouble(text.getText());
Double fvalue = cvalue * 1.8 + 32;
fahrenheitValue.setText(Double.toString(fvalue));
MessageLabel.setText("Conversion Performed Successfully. ");
fahrenheitValue.setText(" ");
new TemperatureConverter();
I can run normal SWT programs like HelloSWT, creating a few buttons etc.
But this time I am getting these errors.
Exception in thread "main" java.lang.ClassCastException: org.eclipse.swt.layout.GridData cannot be cast to org.eclipse.swt.layout.RowData
at org.eclipse.swt.layout.RowLayout.layoutHorizontal(RowLayout.java:251)
at org.eclipse.swt.layout.RowLayout.layout(RowLayout.java:240)
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.java:1290)
at org.eclipse.swt.widgets.Composite.sendResize(Composite.java:981)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:1026)
at org.eclipse.swt.widgets.Decorations.setBounds(Decorations.java:887)
at org.eclipse.swt.widgets.Shell.setBounds(Shell.java:1505)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:3104)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:3100)
at demo1.TemperatureConverter.<init>(TemperatureConverter.java:44)
at demo1.TemperatureConverter.main(TemperatureConverter.java:79)
Please help me out as soon as possible..
Thanks in advance
FUDForum. Page generated in 0.03096 seconds
