Setting String attribute back to null [message #1707989] |
Fri, 11 September 2015 09:14 |
Dear all,
When using an stereotyped element with a String tag value I don't know
how to set it to null.
Initially it has a null value, because if I run the validation and the
attribute is mandatory I get the right validation error, but if I set it
to something else I don't know to set it back to null again. Is it possible?
Best,
Víctor
Re: Setting String attribute back to null [message #1729904 is a reply to message #1729779] |
Wed, 20 April 2016 08:09 |
Unfortunately I didn't. What I did is changing the validation functions
to check also for empty Strings, but depending on you problem that might
not be a solution.
I do think Papyrus should support that natively.
Best,
Víctor
El 19/04/2016 a las 14:17, Chris Wilkinson escribió:
> Did you find a solution to this? I have the same issue.
FUDForum. Page generated in 0.02254 seconds
