Silent installation of Jubula [message #1707679] |
Tue, 08 September 2015 09:33  |
Hi all,
I've been requested to make a silent install of software to a Ubuntu 64 bit virtual machine of certain software. One of these items is to install a sprint release of Jubula (Found here: http://testing.bredex.de/jubula-beta-releases.html)
I've downloaded the .sh file for linux and attempted to add it to the script using :
But it will fail because there are some questions asked during the install. These questions are:
This will install Jubula on your computer.
OK [o, Enter], Cancel [c]
Several lines requesting enter to be press to accept the license agreement
I accept the agreement
Yes [1], No[2]
Where should Jubula be installed?
[/opt/jubula_1.8.7.045]
Which components should be installed?
[Enter] for the default selection [1,2,3,4]
Create symlinks?
Yes [y, Enter], No [n]
Select the folder where you would like Jubula to create symlinks, then click next.
[/usr/local/bin]
Is there any method to do silent install and accept the default on these options? I've checked after installation, but nothing is in there that appears to assemble what Jubula was requesting.
If that is possible, is it also possible to pass an XML file to Jubula upon start up to be imported into the default testing database?
Hope you can help!
Tom
FUDForum. Page generated in 0.03541 seconds
