Home » Eclipse Projects » RCP Testing Tool » Setting spaces instead of tabs for RCPTT editor
Setting spaces instead of tabs for RCPTT editor [message #1707361] Fri, 04 September 2015 01:05 Go to next message
I can't seem to find any other option about this aside from General --> Editors --> Text Editors -> Insert spaces for tabs. I already set this and when I highlight a piece of code and do a tab or CTRL+F, tabs are still used instead of spaces.
Is this a missing feature? Will it be always tab instead of spaces in the RCPTT editor?
Re: Setting spaces instead of tabs for RCPTT editor [message #1710988 is a reply to message #1707361] Mon, 12 October 2015 03:45 Go to previous messageGo to next message
Hi Karl,
Does this option works well for you in simple Java Editor?
Because I can't make it work. Could you please give some steps to reproduce?
Kind regards,
Ulyana.
Re: Setting spaces instead of tabs for RCPTT editor [message #1711004 is a reply to message #1710988] Mon, 12 October 2015 05:36 Go to previous messageGo to next message
Ulyana Skorokhodova wrote on Mon, 12 October 2015 03:45
Hi Karl,
Kind regards,
Ulyana.
I don't quite get what you mean? Are you saying if I can set spaces instead of tabs for a Java Editor?
Regarding reproducing the steps, the steps are.
1. Type your code, do your own formatting by maybe indenting using spaces.
2. Do a CTRL+F, all the indentation that were previously spaces are now tabs.
Re: Setting spaces instead of tabs for RCPTT editor [message #1711013 is a reply to message #1711004] Mon, 12 October 2015 07:02 Go to previous messageGo to next message
Hi Karl,
I've just re-checked this in RCPTT editor and that's how it is working for me now:
1) When the option "Insert spaces for tabs" in enabled, 4 spaces are inserted when you press Tab button;
2) When the option is disabled tab is inserted when you press Tab button.
After the formatting all 4-spaces are replaced with tabs.
Does it work the same on your side?
Kind regards,
Ulyana.
Re: Setting spaces instead of tabs for RCPTT editor [message #1715366 is a reply to message #1711013] Sun, 22 November 2015 22:24 Go to previous message
Hi Karl,
Any update on this?
Kind regards,
Ulyana.
Previous Topic:Can't install RCPTT into eclipse 4.0
Next Topic:Problem with MouseClick into Table
Current Time: Thu May 22 16:31:35 EDT 2025
Powered by FUDForum. Page generated in 0.03538 seconds
