Home » Modeling » UML2 » Stereotype attribute using ATL(Picking (deriving) Stereotype attribute using ATL in Eclipse Luna)
Stereotype attribute using ATL [message #1707183] |
Wed, 02 September 2015 21:03 |
Karishma Karishma Messages: 4 Registered: September 2015 |
Hey,
Could someone help me with the code for deriving the Stereotype Attributes name and properties. I have a message which is related to a lifeline. The lifeline is linked to a schedulable resource which is further allocated a hardware processor.
I am using Eclipse Luna and UML 5.0
In the code i am trying to pick the schedulableResource linked to the lifeline and the then the hardware processor allocated to it. But i am not able to do it....
Any help would be appreciated....
Code:
helper context UML!Element def: hasStereotype(stereotype : String) : Boolean =
self.getAppliedStereotypes() -> collect(st | st.name) -> includes(stereotype);
helper context UML!Lifeline def: getLifelineHost (): String =
if (self.hasStereotype('PaRunTInstance'))
then
self.getValue(self.getAppliedStereotype('PaRunTInstance'),'host')
else
endif;
rule MessageToConnector
from
m: UML!Message
using
mosr:UML!MessageOccurrenceSpecification = m.receiveEvent;
llr: UML!Lifeline = mosr.covered.first();
to
c : QNModel!Connector
name<- llr.getLifelineHost()
do
'ruleMessageToConnectorStarts'.println();
'receiver lifeline'.println();
llr.name.println();
It gives me the following error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: IN!User.getValue(org.eclipse.m2m.atl.engine.emfvm.lib.OclUndefined,java.lang.String)
at getLifelineHost#11(UML2QN.atl[20:7-20:72])
local variables: self=IN!User
at __applyMessageToConnector#20(UML2QN.atl[94:11-94:32])
local variables: self=UML2QN : ASMModule, link=TransientLink {rule = MessageToConnector, sourceElements = {m = org.eclipse.uml2.uml.internal.impl.MessageImpl@4eee2a3c (name: think time, visibility: <unset>) (messageSort: asynchCall)}, targetElements = {c = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@109a492c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@d060492 (name: Connector) (instanceClassName: null) (abstract: false, interface: false))}, variables = {mosr = org.eclipse.uml2.uml.internal.impl.MessageOccurrenceSpecificationImpl@25da6960 (name: MessageRecv, visibility: <unset>), llr = org.eclipse.uml2.uml.internal.impl.LifelineImpl@688a9461 (name: User, visibility: <unset>)}}, m=IN!think time, c=OUT!<unnamed>, mosr=IN!MessageRecv, llr=IN!User
at __exec__#38(UML2QN.atl)
local variables: self=UML2QN : ASMModule, e=TransientLink {rule = MessageToConnector, sourceElements = {m = org.eclipse.uml2.uml.internal.impl.MessageImpl@4eee2a3c (name: think time, visibility: <unset>) (messageSort: asynchCall)}, targetElements = {c = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@109a492c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@d060492 (name: Connector) (instanceClassName: null) (abstract: false, interface: false))}, variables = {mosr = org.eclipse.uml2.uml.internal.impl.MessageOccurrenceSpecificationImpl@25da6960 (name: MessageRecv, visibility: <unset>), llr = org.eclipse.uml2.uml.internal.impl.LifelineImpl@688a9461 (name: User, visibility: <unset>)}}
at main#24(UML2QN.atl)
Current Time: Mon Aug 08 23:50:04 GMT 2022
Powered by FUDForum. Page generated in 0.02218 seconds
