Home » Language IDEs » Java Development Tools (JDT) » How to connect MySQL database in Java ?(I am coding a module in java that need a database connection with MySQL)
How to connect MySQL database in Java ? [message #1706781] Mon, 31 August 2015 01:30 Go to next message
I am coding a module in java that need a database connection with MySQL. I heard about DriverManager but I think it is pretty old method for database connection. Is there any newer and efficient way of doing the same. This Java questions and answers forum comprises of large number of tech and coding expert, So I expect quick and satisfactory solution or full set of instruction/ code require for this.
Re: How to connect MySQL database in Java ? [message #1706899 is a reply to message #1706781] Mon, 31 August 2015 12:49 Go to previous message
Perhaps you should ask in a Java forum, like maybe stackoverflow.com. This is for the Java Development Tools found in and used by Eclipse.
Previous Topic:Getting a Project From Github to Eclipse
Next Topic:HTML5 <main> tag not recognised
Current Time: Thu May 15 03:34:14 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
