Home » Eclipse Projects » NatTable » How to Use Wild-card Filter Support in NatTable(Wild-card Filter support for Nat table)
How to Use Wild-card Filter Support in NatTable [message #1706644] Fri, 28 August 2015 07:27 Go to next message
Dear All,
I Created a nat table with the filter row header and use the filter list and DefaultGlazedListsFilterStrategy like below
// build the filter strategy to filter the table data
DefaultGlazedListsFilterStrategy<Object> filterStrategy = new DefaultGlazedListsFilterStrategy<Object>(
filterList, IColumnPropertyAccessor
configRegistry);
// Configure the regular expression filter on Column
configRegistry.registerConfigAttribute(
FilterRowConfigAttributes.TEXT_MATCHING_MODE,
TextMatchingMode.REGULAR_EXPRESSION, DisplayMode.NORMAL, 5) ;
but when i filter with the pattern "*abc", the filter is not working, it is not giving the result with name as expected [for example: expectation here is filter should provide the filterList with the data like xyzabc, pqrabcty].
so how to make it possible?
Thank you
Shashi
Re: How to Use Wild-card Filter Support in NatTable [message #1706646 is a reply to message #1706644] Fri, 28 August 2015 08:14 Go to previous messageGo to next message
I think the label you are registering the TEXT_MATCHING_MODE for is wrong. It should be
FilterRowDataLayer.FILTER_ROW_COLUMN_LABEL_PREFIX + 5
instead of only 5
Re: How to Use Wild-card Filter Support in NatTable [message #1706805 is a reply to message #1706646] Mon, 31 August 2015 05:45 Go to previous messageGo to next message
Thank you for your kind response.
one more problem is that the filter works only for the "*" delimiter because i register only '*' delimiter.
FilterRowConfigAttributes.TEXT_DELIMITER, "*");
but it is not working for other regular expression.
For example : if Enter ^123 [Any character except 123 (negation)] should display, but the filter is not working as expected in this case.
if i do register like
FilterRowConfigAttributes.TEXT_DELIMITER, "^");
here the filter behavior is same for both * and ^ but it should not be , so how to achieve the filter should work for regular expressions correctly.
Thank you
Shashi
Re: How to Use Wild-card Filter Support in NatTable [message #1706815 is a reply to message #1706805] Mon, 31 August 2015 07:09 Go to previous messageGo to next message
TEXT_DELIMITER is used to be able add several filter conditions, e.g. to support an AND condition. In our examples this is done by registering the & sign. I don't understand why you are using a delimiter for your use case.
Your regular expression is not correct. If you want to show everything except 123 it should be ^(123)
Re: How to Use Wild-card Filter Support in NatTable [message #1706822 is a reply to message #1706815] Mon, 31 August 2015 08:03 Go to previous messageGo to next message
Thank you Dirk for your valuable input.
If i didn't use TEXT_DELIMITER the filter will not work and throw the following
Warning.
org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsFilterStrategy applyFilter
WARNING: Error on applying a filter: Dangling meta character '*' near index 0
if i add the TEXT_DELIMITER for "*" the warning wont throw and filter work
only for this * sign not for others.
Even i check for some columns in the example _6031_GlazedListsFilterExample
in this example also the behavior same as above.
is it required any extra configuration, if not why it is not working?
Thank you
Shashi
Re: How to Use Wild-card Filter Support in NatTable [message #1706823 is a reply to message #1706822] Mon, 31 August 2015 08:15 Go to previous messageGo to next message
Maybe you need to get familiar with regular expressions first.
https://docs.oracle.com/javase/tutorial/essential/regex/index.html
The * is a meta character in regular expressions for the quantifier "zero or more times". The exception tells you that you are using a quantifier without an expression where the quantifier should be applied to.
The regular expression you are looking for is (.*)abc, which means "any character, zero or more times, end with abc"
If you want this to be simplified somehow, you might want to implement a converter for the filter row that transforms the user input '*' to a data input '(.*)' and vice versa
Re: How to Use Wild-card Filter Support in NatTable [message #1707025 is a reply to message #1706823] Tue, 01 September 2015 10:59 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=476348
Previous Topic:ColumnOverrideAccumulator to ColumnGroupHeaderLayer or ColumnGroupGroupHeaderLayer
Next Topic:Disable row selection in NatTable
Current Time: Sat Jul 19 05:39:51 EDT 2025
Powered by FUDForum. Page generated in 0.04214 seconds
