Home » Modeling » OCL » template param impl cannot be cast to pivot class(class cast exception)
template param impl cannot be cast to pivot class [message #1706585] Thu, 27 August 2015 21:19 Go to next message
Rick Murphy is currently offline Rick MurphyFriend
Hello Ed:
We met a few years ago at an OMG meeting. Thanks for all your great work on OCL.
The attached ecore file causes the following exception: java.lang.ClassCastException: org.eclipse.ocl.pivot.internal.TemplateParameterImpl cannot be cast to org.eclipse.ocl.pivot.Class
I have also attached the stack trace.
It appears that Zero and Suc are the source of the exception. I am just getting started with OCL, so I can't say more.
Rick
  • Attachment: S0.zip
    (Size: 4.24KB, Downloaded 128 times)
  • Attachment: dump
    (Size: 6.24KB, Downloaded 134 times)
Rick
Re: template param impl cannot be cast to pivot class [message #1706794 is a reply to message #1706585] Mon, 31 August 2015 08:01 Go to previous message
Templates are not supported in OMG OCL even though OCL is UML aligned.
Eclipse OCL prototypes a resolution of this deficiency, but is not yet
fully defined and tested. (It's looking like punctuation will change to
<...> in definitions, but (...) in expressions.)
In your case you re-use the name of a Class as its TemplateParameter;
class Nat<Nat>
This is discouraged if not prohibited in many languages and is surely
poor practice in all.
class Suc<Nat> extends Nat<Nat>
is multiply dubious.
Rename the Nat template parameters and your problem goes away,
Eclipse OCL has a bug with respect to its diagnosis of this problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=476092
Ed Willink
On 27/08/2015 22:19, Rick Murphy wrote:
> Hello Ed:
> Rick
Previous Topic:Cannot access OCL functions
Next Topic:Execution of eclipse OCL source code from GIT Repository
Current Time: Tue Feb 18 15:14:29 GMT 2020
Powered by FUDForum. Page generated in 0.03453 seconds
