Home » Newcomers » Newcomers » PyDev 4.3.0 debugging failure(PyDev debugger won't start after upgrading to 4.3.0)
PyDev 4.3.0 debugging failure [message #1706287] Tue, 25 August 2015 09:23 Go to next message
[Using Eclipse Mars (4.5.0) on OS X 10.10.5, with PyDev 4.3.0]
I recently updated by PyDev plugin from 4.2(?) to 4.3.0 and now when I attempt to debug any of my modules, I get the following error in the Console:
pydev debugger: starting (pid: 9237)
Could not connect to 127.0.0.1: 63574
Traceback (most recent call last):
  File "/Applications/Eclipse.app/Contents/Eclipse/plugins/org.python.pydev_4.3.0.201508182223/pysrc/pydevd.py", line 2275, in <module>
    debugger.connect(host, port)
  File "/Applications/Eclipse.app/Contents/Eclipse/plugins/org.python.pydev_4.3.0.201508182223/pysrc/pydevd.py", line 431, in connect
    self.initializeNetwork(s)
  File "/Applications/Eclipse.app/Contents/Eclipse/plugins/org.python.pydev_4.3.0.201508182223/pysrc/pydevd.py", line 418, in initializeNetwork
    self.writer = WriterThread(sock)
  File "/Applications/Eclipse.app/Contents/Eclipse/plugins/org.python.pydev_4.3.0.201508182223/pysrc/pydevd_comm.py", line 379, in __init__
    self.cmdQueue = _queue.Queue()
TypeError: __init__() missing 1 required positional argument: 'params'
Did I miss something on the PyDev update that I'm not doing right? This is only a problem with the Debug configuration - the Run config for my modules work correctly. I also uninstalled and then reinstalled PyDev, but that did not fix the problem. Thanks for any input here.
Re: PyDev 4.3.0 debugging failure [message #1706310 is a reply to message #1706287] Tue, 25 August 2015 10:59 Go to previous messageGo to next message
> Console:
> File
> File
> File
> File
Conrad,
PyDev isn't created by Eclipse, but by a third party using Eclipse.
You'll need to look to the PyDev community for support as your question
isn't about the Eclipse workbench, but about PyDev functionality itself.
Hope this helps.
Re: PyDev 4.3.0 debugging failure [message #1706311 is a reply to message #1706310] Tue, 25 August 2015 11:03 Go to previous messageGo to next message
I am aware PyDev is a third party plugin. I've posted to other forums, but haven't gotten any response yet, so I'm looking for help anywhere I can get it!
Re: PyDev 4.3.0 debugging failure [message #1706313 is a reply to message #1706311] Tue, 25 August 2015 11:14 Go to previous message
> can get it!
I see that now.
It strikes me as an issue PyDev's author should attend to, but I don't
know how to gain his attention. As I no longer use PyDev for
development, and therefore haven't updated, I don't have this issue
myself. (I did contribute to its author, but that didn't give me any
route into him personally.)
I assume that this very same code work previously, so this is indeed a
PyDev issue.
From my experience though, there is no answer to expect in this or any
Eclipse forum (for reasons first stated).
Best of luck.
Previous Topic:eclipse SCADA installation
Next Topic:Eclipse will not start with JDK 7 and JDK 8 installed
Current Time: Sun Nov 02 05:13:22 EST 2025
Powered by FUDForum. Page generated in 0.09428 seconds
