Starting with Andmore [message #1706149] |
Mon, 24 August 2015 08:17 |
I would like to start using Andmore, but have some problem using wizards.
I installed it starting with Eclipse Mars JEE from the following update site
http://download.eclipse.org/andmore/milestone/0.5-M2/
also have downloaded Google Android SDK and set in
Preferences, Android, SDK Location
Then started with Andmore New Project wizards.
Tried with "Android Application Project", gave name to Project and confirming default values. At the end I get several errors, among them are:
- ActionBarActivity cannot be resolved to a type MainActivity.java
- error: Error retrieving parent for item: No resource found that matches the given name 'Theme.AppCompat.Light'. styles.xml
- R cannot be resolved to a variable MainActivity.java
Tried with "Android Project", gave a name and left other values to default (create new project, Android 5.1.1,...).
When I press Finish I got an empty error popup (just the error icon, empty message), press OK and got a NullPointerException popup.
Which is the right wizard to use for someone who is adopting Andmore?
Is there a tutorial on how to start with simple steps?
Thank you very much.
Vincenzo
FUDForum. Page generated in 0.02771 seconds
