Home » Eclipse Projects » e(fx)clipse » Trying to create an e4 only application with JavaFX
Trying to create an e4 only application with JavaFX [message #1705878] |
Wed, 19 August 2015 18:20 |
Paul Roubekas Messages: 207 Registered: March 2012 Location: Chattanooga, TN USA |
Eclipse for RCP and RAP Developers
Version: Mars Release (4.5.0)
Build id: 20150621-1200
I am trying to develop a band new e4 application using JavaFX. I started off by making the mistake of using the 3.x templates. New -> Plug-in Project -> (Eclipse version 3.5 or greater) -> (This plug-in with make contributions to the UI)-> JavaFX Eclipse 3.x RCP. One thing I was able to do was open my UI drawing by returning a ScrollPane() from the createFxScene() method.
Since I have now realized my mistake I am using the New -> Other -> JavaFX -> OSGi -> e4Application projects as a base set of bundles.
{name}.app.
{name}.app.feature
{name}.app.product
{name}.app.releng
Since I continue to struggle I want to confirm I am going about this the correct way. For now all I want to create is a e4 RCP window split horizontally. The top pane will be pannable(click & drag) & zoomable(mouse wheel) with scroll bars. Each geometric node in the UI drawing has a mouse click listener to bring up a context popup menu (got this working in 3.x). The pop-up menu selection will build the appropriate properties panel in the bottom pane. If appropriate properties panel is already in the bottom pane give it focus.
After configuring the e4 modle with two Parts I am getting the following error when trying to run it from the "Launch an Eclipse application" link of the .product file.
package packarge.twobox.views.parts;
import javax.inject.Inject;
import javax.annotation.PostConstruct;
import javafx.scene.layout.BorderPane;
public class TopBox {
@Inject
public TopBox() {
System.out.println("In class TopBox in constructor.");
@PostConstruct
public void postConstruct(BorderPane parent) {
System.out.println("In class TopBox in postConstruct() method.");
public class BottomBox {
@Inject
public BottomBox() {
System.out.println("In class BottomBox in constructor.");
@PostConstruct
System.out.println("In class BottomBox in postConstruct() method.");
!SESSION 2015-08-19 13:35:56.660 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_51
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product twoobox.app.product
Command-line arguments: -product twoobox.app.product -data C:\EWS\sandbox00/../runtime-twoobox.app.product -dev file:C:/EWS/sandbox00/.metadata/.plugins/org.eclipse.pde.core/twoobox.app.product.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-19 13:35:58.104
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-19 13:35:58.704
!MESSAGE Could not bind a reference of component twoobox.app.themes.default. The reference is: Reference[name = Stylesheet, interface = org.eclipse.fx.ui.services.theme.Stylesheet, policy = dynamic, cardinality = 0..n, target = null, bind = registerStylesheet, unbind = unregisterStylesheet]
Invalid type stored in transient data with the key binding
!ENTRY org.eclipse.equinox.event 4 0 2015-08-19 13:36:00.057
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/widget/SET] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@42acdb8f (elementId: twoobox.app.trimmedwindow.0, tags: [], contributorURI: platform:/plugin/twoobox.app) (widget: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl@219bdf11, renderer: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer@13016ffb, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (twoobox.app.trimmedwindow.0) Context, variables: [], x: 135, y: 52, width: 960, height: 718), Widget=org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl@219bdf11, AttName=widget, NewValue=org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl@219bdf11, EventType=SET} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@4a419798
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl cannot be cast to org.eclipse.swt.widgets.Widget
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
at org.eclipse.fx.ui.workbench.fx.internal.UISynchronizeImpl.syncExec(UISynchronizeImpl.java:88)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:261)
at org.eclipse.fx.ui.workbench.renderers.base.BaseRenderer.bindWidget(BaseRenderer.java:547)
at org.eclipse.fx.ui.workbench.renderers.base.BaseRenderer.bindWidget(BaseRenderer.java:1)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createWidget(PartRenderingEngine.java:247)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createGui(PartRenderingEngine.java:211)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createGui(PartRenderingEngine.java:311)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.run(PartRenderingEngine.java:439)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.fx.ui.workbench.fx.E4Application$1.lambda$0(E4Application.java:181)
at org.eclipse.fx.ui.workbench.fx.E4Application$1$$Lambda$63/673438503.run(Unknown Source)
at org.eclipse.fx.ui.workbench.fx.E4Application$1.run(E4Application.java:170)
at org.eclipse.fx.ui.workbench.fx.E4Application.jfxStart(E4Application.java:193)
at org.eclipse.fx.ui.workbench.fx.DefaultJFXApp.start(DefaultJFXApp.java:57)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$159(Unknown Source)
at com.sun.javafx.application.LauncherImpl$$Lambda$58/1476900590.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$172(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$53/1275102761.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl.lambda$null$170(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$56/577084506.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$171(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$54/111992132.run(Unknown Source)
at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(Unknown Source)
at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
at com.sun.glass.ui.win.WinApplication.lambda$null$145(Unknown Source)
at com.sun.glass.ui.win.WinApplication$$Lambda$44/1831394443.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassCastException: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl cannot be cast to org.eclipse.swt.widgets.Widget
at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDAddon.subscribeTopicWidget(DnDAddon.java:38)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 42 more
Oxygen 3a
Windows 10
Re: Trying to create an e4 only application with JavaFX [message #1705907 is a reply to message #1705905] |
Wed, 19 August 2015 23:37 |
Progress!! But not working.... yet. I am getting the following binding errors now.
!SESSION 2015-08-19 19:29:34.632 -----------------------------------------------
Framework arguments: -product TwoBox.app.product
Command-line arguments: -product TwoBox.app.product -data C:\EWS\sandbox00/../runtime-TwoBox.app.product -dev file:C:/EWS/sandbox00/.metadata/.plugins/org.eclipse.pde.core/TwoBox.app.product.product/dev.properties -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-19 19:29:36.717
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-19 19:29:37.388
!MESSAGE Could not bind a reference of component TwoBox.app.themes.default. The reference is: Reference[name = Stylesheet, interface = org.eclipse.fx.ui.services.theme.Stylesheet, policy = dynamic, cardinality = 0..n, target = null, bind = registerStylesheet, unbind = unregisterStylesheet]
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-08-19 19:29:37.902
!MESSAGE Unable to create class 'org.eclipse.fx.ui.keybindings.e4.BindingProcessingAddon' from bundle '61'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:278)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:107)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:50)
at org.eclipse.fx.ui.workbench.base.AbstractE4Application.createE4Workbench(AbstractE4Application.java:280)
at org.eclipse.fx.ui.workbench.fx.E4Application.initE4Workbench(E4Application.java:284)
at org.eclipse.fx.ui.workbench.fx.E4Application$1.run(E4Application.java:153)
at com.sun.javafx.application.LauncherImpl$$Lambda$58/1364732931.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$54/1443285689.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$56/1939928008.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$55/1444803259.run(Unknown Source)
at com.sun.glass.ui.win.WinApplication$$Lambda$44/831719902.run(Unknown Source)
Caused by: java.lang.NullPointerException
at org.eclipse.fx.ui.keybindings.e4.internal.BindingTable$BindingComparator.compare(BindingTable.java:91)
at org.eclipse.fx.ui.keybindings.e4.internal.BindingTable$BindingComparator.compare(BindingTable.java:1)
at java.util.TimSort.countRunAndMakeAscending(Unknown Source)
at java.util.TimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.ArrayList.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
at org.eclipse.fx.ui.keybindings.e4.internal.BindingTable.addBindingSimple(BindingTable.java:252)
at org.eclipse.fx.ui.keybindings.e4.internal.BindingTable.evaluateOrderedBindings(BindingTable.java:364)
at org.eclipse.fx.ui.keybindings.e4.internal.BindingTable.addBinding(BindingTable.java:238)
at org.eclipse.fx.ui.keybindings.e4.BindingProcessingAddon.defineBinding(BindingProcessingAddon.java:141)
at org.eclipse.fx.ui.keybindings.e4.BindingProcessingAddon.defineBindingTable(BindingProcessingAddon.java:132)
at org.eclipse.fx.ui.keybindings.e4.BindingProcessingAddon.defineBindingTables(BindingProcessingAddon.java:117)
at org.eclipse.fx.ui.keybindings.e4.BindingProcessingAddon.init(BindingProcessingAddon.java:86)
... 27 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-08-19 19:29:37.972
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.cleanupaddon.CleanupAddon
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-08-19 19:29:37.973
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-08-19 19:29:37.974
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.dndaddon.DnDAddon
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.addons.swt/org.eclipse.e4.ui.workbench.addons.splitteraddon.SplitterAddon
Oxygen 3a
Windows 10
Re: Trying to create an e4 only application with JavaFX [message #1705908 is a reply to message #1705907] |
Wed, 19 August 2015 23:47 |
I added to the end of the existing "Arguments" string the following.
-persistState false -clearPersistedState
Now each launch only comes with the following errors.
!SESSION 2015-08-19 19:46:48.625 -----------------------------------------------
Framework arguments: -product TwoBox.app.product -nosplash-persistState false -clearPersistedState
Command-line arguments: -product TwoBox.app.product -data C:\EWS\sandbox00/../runtime-TwoBox.app.product -dev file:C:/EWS/sandbox00/.metadata/.plugins/org.eclipse.pde.core/TwoBox.app.product.product/dev.properties -consoleLog -nosplash-persistState false -clearPersistedState
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-19 19:46:50.211
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-19 19:46:50.792
Oxygen 3a
Windows 10
[Updated on: Wed, 19 August 2015 23:55] Report message to a moderator
Re: Trying to create an e4 only application with JavaFX [message #1705932 is a reply to message #1705908] |
Thu, 20 August 2015 08:51 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Those are not really errors in the sense of your application but a bug
in Equinox-DS which croaks about totally legal stuff.
Tom
> java.vendor=Oracle Corporation
Current Time: Fri Apr 19 22:16:59 GMT 2024
Powered by FUDForum. Page generated in 0.04200 seconds
