Re: Problem in edge ceration of an element based edge [message #1705655 is a reply to message #1705553] |
Tue, 18 August 2015 07:56 |
On 08/17/2015 03:17 PM, Nawel Amok wrote:
> Hello,
Hello Nawel,
The Edge Creation Tool will create a new instanceof
ExternalEnterpriseOutput by using a "Create Instance". The context will
be the semantic element that will hold this object (it seems to be
ContextView in your meta-model).Next, you need to specify in the "Create
Instance" properties the reference name (from the context) where this
new instance will be hold.
Florian
> In my DSL, an output from an enterprise to its partner is modelled with a labeled edge.
> I can't seem to manage the creation of this edge ("Sortie" associated to the domain class "ExternalEnterpriseOutput") in the tool section.
> What exactly should the Context be ?? I thought it was the root element of the diagram here the container of this edge...
> I attached my projects, the problem is in the context view viewpoint.
> Would you please tell me what am I missing ?
> Thanks in advance,
> Nawel
Florian - Obeo
FUDForum. Page generated in 0.02093 seconds
