Re: Can't run simple hello world project: "....exe has stopped working" [message #1705587 is a reply to message #1705491] |
Mon, 17 August 2015 15:50 |
On 08/17/2015 05:51 AM, matt matt wrote:
> Hello everybody!
> I'm pretty frustrated with how much more difficult it is to get Eclipse
> working for simply C coding as opposed to using Notepad++ with cygwin.
> I've followed the instructions (from a website which I cannot link
> because I'm new here...) to get this setup and working:
> install cygwin with gcc-core, gdb, make
> add "C:\cygwin64\bin" to Path
> install eclipse and start a "C Project"
> select "Hello World ANSI C Project" and the toolchain "Cygwin GCC"
> Then I first build the program which works as expected. But running
> results in
> the message "Hello_World.exe has stopped working". When I execute the
> exe in cygwin however, it works fine!
> What's the problem with Eclipse?
There's a separate Eclipse CDT forum.
FUDForum. Page generated in 0.08735 seconds
